Aller au contenu principal
bObi Robotic Vacuum Main Brush Motor Replacement
Ce dont vous avez besoin
  1. bObi Robotic Vacuum Main Brush Motor Replacement, Main brush motor: étape 1, image 1 de 3 bObi Robotic Vacuum Main Brush Motor Replacement, Main brush motor: étape 1, image 2 de 3 bObi Robotic Vacuum Main Brush Motor Replacement, Main brush motor: étape 1, image 3 de 3
    • Remove bObi's dustbin. Press the small latch on the back and it will pop out.
    • Uninstall the 2 screws close to bObi’s dustbin, plus 2 smaller screws above the main brushes.
  2. bObi Robotic Vacuum Main Brush Motor Replacement: étape 2, image 1 de 3 bObi Robotic Vacuum Main Brush Motor Replacement: étape 2, image 2 de 3 bObi Robotic Vacuum Main Brush Motor Replacement: étape 2, image 3 de 3
    • To detach the brushes completely, unplug them from bObi.
    • The motor is on the bottom of the main brush attachment. Uninstall the four screws which secure it, then lift the motor out.
    • Remove the stabilizer attached to the motor’s end, closer to its circuit plug before pulling the whole piece out.
  3. bObi Robotic Vacuum Main Brush Motor Replacement: étape 3, image 1 de 3 bObi Robotic Vacuum Main Brush Motor Replacement: étape 3, image 2 de 3 bObi Robotic Vacuum Main Brush Motor Replacement: étape 3, image 3 de 3
    • Slide the long metal end in first, through the second stabilizer, so the end fits inside the motor holder.
    • Place the stabilizer you removed previously on the new motor.
  4. bObi Robotic Vacuum Main Brush Motor Replacement: étape 4, image 1 de 2 bObi Robotic Vacuum Main Brush Motor Replacement: étape 4, image 2 de 2
    • Align the stabilizer with the screw posts on the brush holder, then install all four screws.
    • Connect the motor’s circuit plug.
    • Place the main brush attachment in bObi so it sits flat.
    • Line up the red fastener on bObi, and replace its two smaller screws.
  5. bObi Robotic Vacuum Main Brush Motor Replacement: étape 5, image 1 de 2 bObi Robotic Vacuum Main Brush Motor Replacement: étape 5, image 2 de 2
    • Lay the two screw holders down. Then install each screw.
    • Slide bObi's dustbin back in until it locks in place.
Chelsea
Membre depuis le 09/24/14
2 278 Réputation
31 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 308
