Introduction
The step-by-step motherboard dis-assembly and installation guide, with directions for every circuit plug connection. Video instructions available at https://www.youtube.com/watch?v=CtnfOtEF...
Ce dont vous avez besoin
Flip Bob over and remove the 7 screws around which hold the cover together.
Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall.
Remove three circuit plugs from the motherboard. Pinch the small white tab on the side of each circuit plug and pull straight up to release each from the motherboard.
1. On the bottom left corner: a small connector with red, black and white wires.
2. One thick white wire that attaches on the right side of the previous connector.
3. On the top edge of bOb’s motherboard: a wide multicoloured connector.
Place the cover aside and begin your repair.
After opening bObsweep, you will see the main board in the center. To remove it, you will need to unplug 11 more circuit plugs and uninstall 3 screws.
There is one in the centre of the motherboard, near the multicoloured plug for Bob’s left wheel.
The second is close to the top right corner.
The third is near the bottom right edge.
Detach all of the motherboard's circuit plugs. Keep note of where each plug attaches for installation of the new one.
Lift the main board up and replace it with a new functional one. Make sure the replacement main board lies flat on top of the screw posts inside bObsweep.
Re-install the 3 screws you removed in the previous step.
The order along the motherboard’s left edge from the top down is:
A small yellow and black circuit plug.
The main brush motor's circuit plug which has two pairs of twisted wires, one red and white, the other pink and black.
A wider, multicoloured circuit plug which is attached to bObsweep’s left wheel.
Finally, a small circuit plug with black and blue twisted wires.
When all have been connected to bObsweep, begin putting the cover back together before vacuuming again.
The order from left to right along the bottom ledge should be reconnected as follows:
A circuit plug with multicolored wires and a wide base which connects to Bob's right wheel.
A small black and orange wired circuit plug
A small yellow wired plug.
A small circuit plug with red, black, white, and brown wires.
To reassemble, see the guide on Closing bObsweep.
4 commentaires
where do you plug black and orange into mother board
where do you plug black and orange wire commiing from dirt bin into 2 plugs empty j7 j23
why dont my bob sweep lights go on when i put it in checkup mode my wheels turn backward forward like they should vacum bin starts like it should my maun board shows battrey 4 bars ready for work but will only go 3 minunets then it wants to dock can i run this vac effecintly with dock stationit got lost
why dont my bob sweep lights go on the four when i put it in checkup mode when i lift it weehls will turn back and forward like they should vac will start in that mde to but ui light will not com on all other foctions will not work in checkup mode my battrey shows only 4 bars shows it ready to go will only do 3 minunets then it stops looks for charge base wonering if i can run this vac efficently with out charge base it got lost
