Aller au contenu principal
Pour réparer ensemble - Je crée un compte
eMac PRAM Battery Replacement
Ce dont vous avez besoin
  1. eMac PRAM Battery Replacement, PRAM Battery: étape 1, image 1 de 2 eMac PRAM Battery Replacement, PRAM Battery: étape 1, image 2 de 2
    • Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you.
  2. eMac PRAM Battery Replacement: étape 2, image 1 de 2 eMac PRAM Battery Replacement: étape 2, image 2 de 2
    • The access panel is held in place by one Phillips screw. Unscrew it.
    • Unplug the machine after touching the metal housing to prevent ESD (electro static discharge)
  3. eMac PRAM Battery Replacement: étape 3, image 1 de 1
    • The battery is located just to the left and below the RAM slots.
    • Note the positive is to the right and negative to the left. There is a + sign located on the logic board to the right of the battery.
    • Care must be taken when removing the battery to prevent it dropping into the machine. It pulls straight out. Use a small instrument like a dental pick or flathead screwdriver to lift the + end out. I use a large hemostat to hold the battery.
    • After removal of the old battery and replace with a new one by pressing it into place.
    • Replace the access panel. Turn it over and plug it in. Start up and go under the Apple to System Preferences - System - Date & Time. If you have an internet connection check the box to automatically and select Apple Americas.
    • If no internet just set the date and time manually.
    • Next select the Time Zone box. Click the curser on the map to the closest city to you.
    • Next click the Clock box and select the type of display you prefer.
26 autres ont terminé cette réparation.
mayer
Membre depuis le 01/04/10
690 018 Réputation
11 tutoriels rédigés
1 commentaire de tutoriel
Alguien sabe el.modo serie de la batería???? Todo muy bien pero faltó lomas importante el modelo serie o número de pieza de la bateria
ru vera - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 17
30 derniers jours : 65
Total : 24,528
