Aller au contenu principal
eMac RAM Replacement
Ce dont vous avez besoin
  1. eMac RAM Replacement, RAM: étape 1, image 1 de 3 eMac RAM Replacement, RAM: étape 1, image 2 de 3 eMac RAM Replacement, RAM: étape 1, image 3 de 3
    • The 700MHz thru the second 1 GHz models use PC 133 sticks. The maximum RAM is 1 GB. The second two 1 GHz models and higher machines use PC 2700 memory sticks and have a maximum RAM of 2GB.
    • Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you.
  2. eMac RAM Replacement: étape 2, image 1 de 2 eMac RAM Replacement: étape 2, image 2 de 2
    • The access panel is held in place by one Phillips screw. Unscrew it.
    • Unplug the machine after touching the metal housing to prevent ESD (electro static discharge)
  3. eMac RAM Replacement: étape 3, image 1 de 2 eMac RAM Replacement: étape 3, image 2 de 2
    • There are two RAM slots. Release the RAM by pushing the white outer tabs. Then pull the RAM straight out.
    • Place new RAM in slots and press with both thumbs on each end till you feel them seat.
    • Replace the access panel. Turn it over and plug it in. Boot the machine up and click the Apple logo in the menu bar and then go to "about this Mac", to check to see that the RAM is being recognised properly.
29 autres ont terminé cette réparation.
mayer
Membre depuis le 01/04/10
685 331 Réputation
12 tutoriels rédigés
Équipe
MacHale Enterprises Membre de l'équipe MacHale Enterprises
Business
1 membre
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 38
Total : 20,990
