Aller au contenu principal
iBook G3 14" Lower Case Replacement
Ce dont vous avez besoin
  1. iBook G3 14" Lower Case Replacement, Battery: étape 1, image 1 de 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G3 14" Lower Case Replacement, Lower Case: étape 2, image 1 de 1
    • Use a pin to remove the three rubber feet from the lower case.
  3. iBook G3 14" Lower Case Replacement: étape 3, image 1 de 1
    • Remove the three newly-revealed Phillips screws.
  4. iBook G3 14" Lower Case Replacement: étape 4, image 1 de 1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
  5. iBook G3 14" Lower Case Replacement: étape 5, image 1 de 1
    • Remove the three hex screws using a T8 Torx screwdriver.
    • The screw in the center is shorter than the other two.
  6. iBook G3 14" Lower Case Replacement: étape 6, image 1 de 1
    • Remove the two Phillips screws on either side of the battery contacts.
  7. iBook G3 14" Lower Case Replacement: étape 7, image 1 de 1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
  8. iBook G3 14" Lower Case Replacement: étape 8, image 1 de 1
    • There is a slot on the wall of the battery compartment that locks the lower case in place.
    • Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
  9. iBook G3 14" Lower Case Replacement: étape 9, image 1 de 1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case.
    • Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
  10. iBook G3 14" Lower Case Replacement: étape 10, image 1 de 1
    • Continue to run the spudger around the front, right corner.
    • There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
  11. iBook G3 14" Lower Case Replacement: étape 11, image 1 de 1
    • Once the front and sides of the lower case are free, turn the computer so that the back is facing you.
    • Pull the lower case up and toward you until the back tabs pop free.
    • It may be helpful to jiggle the case up and down.
  12. iBook G3 14" Lower Case Replacement: étape 12, image 1 de 1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
2 autres ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 4,286
