Introduction
Replace or change the CD drive faceplate.
Use a coin to turn both battery locking screws 90 degrees to the left.
  • Use a coin to turn both battery locking screws 90 degrees to the left.
  • Remove the battery cover.
  • Remove the battery from the computer by pulling up on the plastic tab.
Ajouter un commentaire
Use a straightened paperclip to manually eject the CD-ROM tray.
  • Use a straightened paperclip to manually eject the CD-ROM tray.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the single black Phillips screw from the center of the CD-ROM bezel.
  • Remove the single black Phillips screw from the center of the CD-ROM bezel.
Grasp the CD-ROM bezel and rotate it upward to remove it from the drive.
  • Grasp the CD-ROM bezel and rotate it upward to remove it from the drive.
If you rotate the bezel upward as described- you SNAP OFF THE TAB THAT YOU REMOVED THE SCREW FROM, which is what ATTACHES the bezel to the drive!!!. THANKS!
quayd - Réponse
4 autre(s) ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 24/09/2009
1 Réputation
750 tutoriels rédigés
There are two small black phillips screws which ALSO need to be removed ...... on some models. Although appearing identical, these covers are "similar" but NOT interchangeable between models of CD-Rom.
John Foster - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 8,705
