Introduction
Changing the top case will also allow you to replace the trackpad if you need a new one.
Ce dont vous avez besoin
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the following 7 screws from the edges of the keyboard area.
Three 2 mm Phillips along the right edge.
One 4.5 mm Phillips underneath where the magnet was.
One 6 mm Phillips with a small head in the lower left corner.
Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle
12 autres ont terminé cette réparation.
