Introduction
Replacing this keyboard is easy and takes only a few minutes.
Use a coin to rotate the battery locking screw 90 degrees clockwise. Lift the battery out of the computer.
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
Ajouter un commentaire
Pull the keyboard release tabs (shown in yellow) toward you and lift up on the keyboard until it pops free.
  • Pull the keyboard release tabs (shown in yellow) toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (shown in orange) 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Loosen the four silver Phillips screws that secure the RAM shield.
  • Loosen the four silver Phillips screws that secure the RAM shield.
  • These screws will not come out all the way. The screws are held captive to the RAM shield to prevent them from getting lost.
Remove the RAM shield from the computer.
  • Remove the RAM shield from the computer.
  • The four captive screws will come out with the RAM shield.
Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
  • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
  • When reassembling your iBook, make sure that you reconnect the keyboard cable before replacing the RAM shield.
8 autre(s) ont terminé cette réparation.
Pièces jointes
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 29
Total : 10,546
