Place the device on a flat surface as shown. Remove the battery case cover and batteries. Remove the battery case cover and batteries.
  • Place the device on a flat surface as shown.
  • Remove the battery case cover and batteries.
Ajouter un commentaire
Unscrew the four outer 1.0 mm screws with a Phillips head #1 screwdriver. The screws are magnetized in position and will require tweezers to be removed. Unscrew the 0.6 mm screw located in the center of the battery case.
  • Unscrew the four outer 1.0 mm screws with a Phillips head #1 screwdriver.
  • The screws are magnetized in position and will require tweezers to be removed.
  • Unscrew the 0.6 mm screw located in the center of the battery case.
  • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  • Remove the back cover carefully; there are many wires that connect it to the device.
Observe the location of the motherboard at the bottom center of the back cover.
  • Observe the location of the motherboard at the bottom center of the back cover.
  • Using a Phillips head #1 screwdriver, carefully unscrew all three 0.4 mm screws from the indicated locations.
  • Set the 0.4 mm screws aside for reassembly.
Using tweezers, gently remove the motherboard from the back cover of the device.
  • Using tweezers, gently remove the motherboard from the back cover of the device.
Note the connection point of each wire to the motherboard.
  • Note the connection point of each wire to the motherboard.
  • Using utility scissors, cut all the wires connecting the motherboard to the device.
Using tweezers, place the new motherboard in the exact position of the old motherboard.
  • Using tweezers, place the new motherboard in the exact position of the old motherboard.
Read the manufacturer instructions for your specific soldering iron before use. Follow all safety instructions and solder at your own risk.
  • Read the manufacturer instructions for your specific soldering iron before use. Follow all safety instructions and solder at your own risk.
  • Position a strip of solder at the point of contact between the motherboard and each individual wire.
  • Solder the wires to the motherboard making sure to follow the manufacturer's instructions, as well as general soldering safety principles.
Using a Phillips head #1 screwdriver, screw the original screws into the correct places to secure the motherboard back in place.
  • Using a Phillips head #1 screwdriver, screw the original screws into the correct places to secure the motherboard back in place.
Amanda
Membre depuis le 13/10/2014
201 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 3-4, Benson Fall 2014 Membre de l'équipe Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 5
Total : 286
