Aller au contenu principal
iHome IH11 Dock Connector Replacement
Ce dont vous avez besoin
  1. iHome IH11 Dock Connector Replacement, Dock Connector: étape 1, image 1 de 1
    • Remove the two 9mm screws that hold on the dock connector with a Phillips #1 Screwdriver.
  2. iHome IH11 Dock Connector Replacement: étape 2, image 1 de 2 iHome IH11 Dock Connector Replacement: étape 2, image 2 de 2
    • Pop the dock connector out of the iHome and gently pull the white plastic plug connected to the dock connector apart.
    • Remove the four 7.0mm screws with a Phillips #1 screwdriver.
  3. iHome IH11 Dock Connector Replacement: étape 3, image 1 de 1
    • Remove both of the black plastic pieces. They should easily slide off of the two guide holes in the circuit board.
    • The dock connector should now be exposed. You can now simply put your new dock connector in the old one's place.
3 autres ont terminé cette réparation.
Nick Knowles
Membre depuis le 04/19/13
21 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 14-9, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 membres
5 tutoriels rédigés
2 commentaires
Where can I buy a replacement dock connector?
A Ross - Réponse
Likewise, this guide isn't much good if it uses parts that are unavailable.
CJ Shumate - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,392
