Ce dont vous avez besoin
Remove any iPod or apple music device connected to the iHome and unplug from any power source.
Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
Remove the plastic slide from its location and set it aside.
Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
Set the plastic covering and the watch battery aside.
Firmly grasp the power connector, which is the plastic rectangular piece with the white and black wires connected to it.
Pull upwards and dislodge the connector.
Using the scissors on your wire strippers, cut the connecting wires.
Using your wire strippers, remove about 1/4 " of the plastic tubing surrounding the end of your exposed wire, careful to not damage the wires.
Using a wire-nut or electrician's tape, connect the wires of the replacement power connector to your exposed wires. Connect white wire to white, and black to black.
