Introduction
This is a replacement guide for the charging dock on the iHome iH5.
Pièces
Aucune pièce nécessaire.
Remove the eight 5/16 inch screws with a #2 Phillips screwdriver.
  • Remove the eight 5/16 inch screws with a #2 Phillips screwdriver.
Ajouter un commentaire
Use tweezers to unplug the three wires connected to the circuit board. If the wires are tight pliers might work better.
  • Use tweezers to unplug the three wires connected to the circuit board. If the wires are tight pliers might work better.
Remove the five 5/16 inch screws from the circuit board.
  • Remove the five 5/16 inch screws from the circuit board.
Flip the circuit board over. There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
  • Flip the circuit board over.
  • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
  • Unplug the eight wires attached to the circuit board with tweezers. If the wires are tight pliers might work better.
    • There is on wire in the orange box.
    • There are two wires in the yellow box.
    • There are five wires in the green box.
Remove the following four screws securing the iHome iH5 charging dock.
  • Remove the following four screws securing the iHome iH5 charging dock.
    • Use a #2 Phillips screwdriver to remove the four screws.
Gently remove the charging dock from the iHome iH5 by pulling it up.
  • Gently remove the charging dock from the iHome iH5 by pulling it up.
Remove the final screws connecting the iH5 charging dock to the plastic holding platform
  • Remove the final screws connecting the iH5 charging dock to the plastic holding platform
    • Use a #2 Phillips screwdriver to remove the 3/8 inch screws.
Replace the old iH5 charging dock with new iH5 charging dock.
  • Replace the old iH5 charging dock with new iH5 charging dock.
Dustin Lamb
Membre depuis le 13/03/2014
103 Réputation
1 tutoriel rédigé
Équipe
New Mexico State, Team 1-6, Easley Spring 2014 Membre de l'équipe New Mexico State, Team 1-6, Easley Spring 2014
NMSU-EASLEY-S14S1G6
5 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 22
Total : 565
