Aller au contenu principal
iHome iH8BR Lower Case Replacement
Ce dont vous avez besoin
  1. iHome iH8BR Lower Case Replacement, Lower Case: étape 1, image 1 de 3 iHome iH8BR Lower Case Replacement, Lower Case: étape 1, image 2 de 3 iHome iH8BR Lower Case Replacement, Lower Case: étape 1, image 3 de 3
    • Unplug the device from the wall outlet, and turn it over so that the buttons are on a flat surface.
    • Use your fingers to pinch the tab in the direction of the "Open" arrow until tab is loose. Pull the tab vertically to remove it.
    • Remove the battery cover and the batteries.
  2. iHome iH8BR Lower Case Replacement: étape 2, image 1 de 2 iHome iH8BR Lower Case Replacement: étape 2, image 2 de 2
    • Slide a spudger under the two front rubber pads to expose two hidden screws.
  3. iHome iH8BR Lower Case Replacement: étape 3, image 1 de 1
    • Remove the following eight screws:
    • Four 15.1 mm Phillips #2 screws near the front of the device.
    • Four 12.7 mm Phillips #2 screws near the back of the device.
    • The slots for the four 12.7 mm screws are very narrow, so you will need a slender, Phillips #2 screwdriver that does not feature replaceable heads in order to reach them.
  4. iHome iH8BR Lower Case Replacement: étape 4, image 1 de 2 iHome iH8BR Lower Case Replacement: étape 4, image 2 de 2
    • Turn the iHome 180 degrees so the speaker grille is facing you. Carefully lift the bottom case away from the rest of the body and tilt it as shown.
    • Be careful and do not yank the bottom case. A white ribbon wire is the only thing that connects the bottom case to the rest of the device.
    • Using a pair of tweezers, detach the white ribbon cable. Make sure to pull on the ribbon, not on the head.
    • The lower case can now be completely removed from the device!
cfredric
Membre depuis le 04/17/13
25 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 12-33, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 12-33, Amido Spring 2013
CPSU-AMIDO-S13S12G33
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 528
