Aller au contenu principal
iHome iP21 Docking Station Pin Replacement
Ce dont vous avez besoin
  1. iHome iP21 Docking Station Pin Replacement, Base: étape 1, image 1 de 3 iHome iP21 Docking Station Pin Replacement, Base: étape 1, image 2 de 3 iHome iP21 Docking Station Pin Replacement, Base: étape 1, image 3 de 3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Docking Station Pin Replacement, Housing: étape 2, image 1 de 2 iHome iP21 Docking Station Pin Replacement, Housing: étape 2, image 2 de 2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Docking Station Pin Replacement, 30-pin docking mount: étape 3, image 1 de 1
    • Locate the 30-pin docking mount on the iP21. The 30-pin docking mount is visible on top of the iP21.
  4. iHome iP21 Docking Station Pin Replacement, Protective cover: étape 4, image 1 de 2 iHome iP21 Docking Station Pin Replacement, Protective cover: étape 4, image 2 de 2
    • Remove the four 4mm screws from the protective cover using the iFixit Phillips #1 bit
  5. iHome iP21 Docking Station Pin Replacement, Ribbon cables: étape 5, image 1 de 3 iHome iP21 Docking Station Pin Replacement, Ribbon cables: étape 5, image 2 de 3 iHome iP21 Docking Station Pin Replacement, Ribbon cables: étape 5, image 3 de 3
    • Grasp plastic cable connector ends
    • Remove the mini circuit board with 30-pin mounting dock from the two black plastic pegs.
    • Rock gently back and forth and pull to detach mini circuit board with 30-pin mounting dock attached.
Brandy
Membre depuis le 10/27/14
601 Réputation
6 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 5
Total : 716
