Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws. Unscrew the four 11mm screws from the base. Pry the base loose using the spudger.
  • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
  • Unscrew the four 11mm screws from the base.
  • Pry the base loose using the spudger.
  • Remove the base by hand.
Ajouter un commentaire
Remove the two black 6mm screws connecting the main circuit board to the housing top. Grasp front housing and back housing firmly.
  • Remove the two black 6mm screws connecting the main circuit board to the housing top.
  • Grasp front housing and back housing firmly.
  • Gently pull front housing from the back housing.
Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
  • Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
Lift speaker assembly Remove four 7mm screws to detach speaker from speaker assembly
  • Lift speaker assembly
  • Remove four 7mm screws to detach speaker from speaker assembly
Brandy
Membre depuis le 27/10/2014
601 Réputation
6 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 120
