Aller au contenu principal
iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement
Ce dont vous avez besoin
  1. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, Outer Base Plate: étape 1, image 1 de 2 iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, Outer Base Plate: étape 1, image 2 de 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: étape 2, image 1 de 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, RAM DIMM: étape 3, image 1 de 2 iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, RAM DIMM: étape 3, image 2 de 2
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
  4. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, Removing the Lower Case: étape 4, image 1 de 1
    • Remove the four 28.07mm Torx #15 screws from the lower case.
  5. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: étape 5, image 1 de 2 iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: étape 5, image 2 de 2
    • Open the base by carefully pulling straight off, do not rotate the cover.
    • Open slowly to ensure that no cables are damaged or disconnected.
  6. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: étape 6, image 1 de 1
    • Squeeze the small black tab and wiggle gently to remove the colored power cable.
    • Do not pull directly on the colored wires.
    • Do not remove black grounding wire.
  7. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement: étape 7, image 1 de 1
    • Grab both sides of the blue connector and firmly pull to remove it from the mother board.
    • Do not pull directly on the ribbon cable.
  8. iMac G4 15" 700 MHz EMC 1873 Internal RAM Replacement, Internal RAM: étape 8, image 1 de 1
    • Release the tabs on each side of the module by pulling them away from the internal RAM
    • Once the tabs are pulled the module will "pop" out and you can slowly remove it.
19 autres ont terminé cette réparation.
Lilly
Membre depuis le 10/11/11
632 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 5-32, Amido Fall 2011 Membre de l'équipe Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 membres
8 tutoriels rédigés
2 commentaires
It's a bit vague. That is, it explains where and how one has access and how the said memory module fits, but most importantly it does not. What kind of memory are we referring to, just as it does not explain the type of memory it has to be and its speed as well as the process of not touching hands with the gold connectors of the memory module
Carlos Sousa - Réponse
Which memory bank is inside Bank 0 or Bank 1?
Michael Inman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 12
30 derniers jours : 37
Total : 11,688
