Pièces
Aucune pièce nécessaire.
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Ajouter un commentaire
Loosen the four Phillips #0 screws.
  • Loosen the four Phillips #0 screws.
Carefully remove the base access panel.
  • Carefully remove the base access panel.
Remove the four 25mm T-15 screws. Remove the four 25mm T-15 screws.
  • Remove the four 25mm T-15 screws.
Open the housing plate. Be gentle with the wires still connected to the logic board  so as not to ruin the cables.
  • Open the housing plate.
  • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
  • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
Remove the 2 torx 10mm screws on the EMI shield Carefully remove shield and copper tape Carefully remove shield and copper tape
  • Remove the 2 torx 10mm screws on the EMI shield
  • Carefully remove shield and copper tape
Remove the 4 10mm torx screws attatched to the drive carrier. The drive carrier includes optical drive and hard drive.
  • Remove the 4 10mm torx screws attatched to the drive carrier.
  • The drive carrier includes optical drive and hard drive.
Grasp the carrier with both hands on each side.
  • Grasp the carrier with both hands on each side.
  • Remove the carrier by lifting up and out.
  • Pull gently but firmly. The carrier is meant to fit snugly.
Flip the removed carrier to the right and pull out power cables.
  • Flip the removed carrier to the right and pull out power cables.
2 autre(s) ont terminé cette réparation.
Courtney
Membre depuis le 06/10/2011
734 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 21-22, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
4 membres
13 tutoriels rédigés
What two screws in step 6
David Hunter - Réponse
We need a "action" shot; we need to show an actual screwdriver unscrewing the screw.
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 14
Total : 1,706
