Introduction
Remove all electrical wires from the computer, and lay the computer flat on its screen. The computer should rest on a smooth, padded surface.
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Ajouter un commentaire
Loosen the four Phillips #0 screws.
  • Loosen the four Phillips #0 screws.
Carefully remove the base access panel.
  • Carefully remove the base access panel.
Remove the RAM Remove the RAM
  • Remove the RAM
11 autre(s) ont terminé cette réparation.
David Hunter
Membre depuis le 05/10/2011
485 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 21-22, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
4 membres
13 tutoriels rédigés
We need to show the RAM being taken off
David Hunter - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 22
Total : 3,895
