Introduction
Use this guide to replace your CR2032 PRAM battery.
Lay the iMac display-side down on a flat surface.
  • Lay the iMac display-side down on a flat surface.
  • Loosen the three Phillips screws securing the rear panel to the iMac.
  • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
Some models (with light sensor) have only the two outboard screws.
Robert Huber - Réponse
Lift the rear panel slightly near the bottom of the iMac. Pull the rear panel toward yourself and remove it from the iMac.
  • Lift the rear panel slightly near the bottom of the iMac.
  • Pull the rear panel toward yourself and remove it from the iMac.
Ajouter un commentaire
Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
  • Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
  • During reinstallation, insert the AirPort card such that the antenna side is nearest the center of the logic board.
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
  • Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
  • Push the spudger away from the AirPort card to disconnect the AirPort antenna.
  • When reassembling your iMac, be sure to insert the AirPort card the way it was before disassembly.
Antenna wire and connector no visable
Joe Cardoza - Réponse
Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
  • Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
Slightly lift the AirPort bracket off the logic board. De-route the AirPort antenna through the slot in the AirPort bracket.
  • Slightly lift the AirPort bracket off the logic board.
  • De-route the AirPort antenna through the slot in the AirPort bracket.
Use a spudger to slide the PRAM battery out from under its socket's metal clip.
  • Use a spudger to slide the PRAM battery out from under its socket's metal clip.
  • Do not bend the metal clip up, as it is brittle and will break.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 19
Total : 10,433
