Aller au contenu principal
iMac G5 20" Model A1145 Hard Drive Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. iMac G5 20" Model A1145 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Disconnect the hard drive thermal sensor from the logic board by pulling its connector toward the top edge of your iMac.
  2. iMac G5 20" Model A1145 Hard Drive Replacement: étape 2, image 1 de 1
    • Remove the two T10 Torx screws securing the hard drive bracket to the inverter.
  3. iMac G5 20" Model A1145 Hard Drive Replacement: étape 3, image 1 de 1
    • Lift the left edge of the hard drive slightly, then pull it toward the left edge of the iMac.
    • When reinstalling your hard drive, make sure not to push the rubber grommets through the chassis with the hard drive mounting pins as retrieving them may require removing the logic board.
  4. iMac G5 20" Model A1145 Hard Drive Replacement: étape 4, image 1 de 1
    • Rotate the hard drive out of the rear case.
    • Disconnect the SATA data cable by pulling its connector away from the hard drive.
  5. iMac G5 20" Model A1145 Hard Drive Replacement: étape 5, image 1 de 1
    • Disconnect the SATA power cable by pulling its connector away from the hard drive.
    • Remove the hard drive from the iMac.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 598
