Introduction
Use this guide to replace a faulty power supply.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Remove the following four screws securing the power supply to the outer case:
One 9.3 mm T10 coarse-threaded screw
One 25 mm T10 coarse-threaded screw
Two 22 mm T10 fine-threaded screws
Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-Out and AC-In cables still attaching it to the iMac.
Disconnect the DC-Out cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
Once the locking mechanism has cleared the socket, pull the DC-Out connector away from the power supply.
49 autres ont terminé cette réparation.
10 commentaires
I avoided this repair for a while. My iMac would not turn on, no fans or response of any kind from pushing the power button. Reapir took me less than 30 minutes and was very straight forward.
is there a fuse in the PCB where it can be replaced instead of replacing the whole power supply unit?
