Danger
Potentiellement dangereux
Risque de blessure si cette procédure n'est pas suivie correctement. Faites preuve de prudence et suivez tous les avertissements.
Danger
Introduction
This guide details removing the logic board in a 2017 iMac 4K in order to upgrade the RAM and the SATA hard drive (for example, if you purchased the Max Your Mac kit).
Some images in this guide were taken from the 2015 model, which has some small visual differences.
If you are replacing/upgrading your hard drive, be sure to clone your existing hard drive onto the replacement drive prior to performing this upgrade to keep your files and operating system in place.
This guide is marked "potentially dangerous" because it requires you to handle a power supply that contains large capacitors. Unplug the iMac and hold the power button down for at least 10 seconds to help discharge the capacitors. Handle the board by the edges and do not touch surface components.
  • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs are fast and easy with an iMac service wedge, but can be completed without one.
  • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
  • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
The wedge is an extremely tight fit for this model. I was worried that the amount of force needed to use it as shown might damage the stand, so I used it with the long side down instead. It worked fine that way and didn’t need anywhere near as much force to insert.
roberttrevellyan - Réponse
Here’s a good YouTube vid on upgrading the RAM: Can a Normal Person Upgrade the RAM in the 2017 21.5" iMac?
Dan - Réponse
Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure. The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
  • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
  • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
Ajouter un commentaire
Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center. Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle. Run the tool up along the left side of the display.
  • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
  • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
  • Run the tool up along the left side of the display.
Erreur de traduction: "de bas en haut" et non de" haut en bas" sur le côté gauche de l'écran
Moreau - Réponse
Continue running the tool up around the top left corner. Continue running the tool up around the top left corner. Continue running the tool up around the top left corner.
  • Continue running the tool up around the top left corner.
Cut the adhesive along the top left of the display. Cut the adhesive along the top left of the display.
  • Cut the adhesive along the top left of the display.
Continue along the top of the display. You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  • Continue along the top of the display.
  • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
In this step can I cut along the display without make any damage to the front camera?
arisnordico - Réponse
Hi! Actually - there is no need to cut the tape around the camera area - there is no tape to cut at all! And so, the way go is easy - just pass 10 mm to the left and to the right from camera and start cutting!
P.S. Just did the whole procedure to replace a RAM and to add SSD on PSIe an hour ago! Seems to be different reading the instructions... you know - 2/10 and so on. But it's really not that hard, trust me. I'll give it 5/10.
P.P.S. By the way there is one trick to pass the difficult steps. Any action which requires pulling smth (motherboard, speaker, power supply unit) from the narrow crack (or should i say - slit?) at the bottom of your Imac is really not so easy.
And the trick is to first remove a thin metal stripe with some kind of insulation on it which held by 5 small (very small!!) screws at the bottom of your Imac. After you done it - it's easy to pull everything! Pay attention to the fact that one of this 5 screws at the center are more shortly than others.
dv1977 - Réponse
After doing the replacement the adhesive still sticks quite good enough to hold the screen in place. Maybe this isn't rock-solid, but enough for me.
Mirko - Réponse
I did all steps like this manuell but now the Display wont work only some colered strips are to see! Whats happend??
Can anybody help me ? Maybe the connector cable is broken?
djfanta - Réponse
Check both connectors, probably one of them not seated well
pzhivulin -
You can add a SATA SSD if you already have a PCIe SSD Factory?
kaserlik - Réponse
If you're changing cracked EMC 2638 display to new assembly, there's two more steps:
Step 24: Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
Carefully pull the display data cable from its socket on the display assembly.
Step 25: Use the tip of a spudger to unplug bracket of the thermal sensor small cable near display data cable.
Carefully remove scotch tape covering thermal sensor. Using iSesamo or flat tip of the spudger carefully peel the thermal sensor away.
pzhivulin - Réponse
omg - forgot to switch the termal sensor from the old display...
now fan runs like crazy...
Andrei Balotescu -
Push the tool around the top right corner of the display. Push the tool around the top right corner of the display. Push the tool around the top right corner of the display.
  • Push the tool around the top right corner of the display.
Wheel the tool down along the right side of the display. Wheel the tool down along the right side of the display.
  • Wheel the tool down along the right side of the display.
Finish pushing the opening tool to the bottom of the right side of the display. At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  • Finish pushing the opening tool to the bottom of the right side of the display.
  • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive. Set the iMac face-up on a table. Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
  • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
  • Set the iMac face-up on a table.
  • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
  • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
this step is extremely important NOT to stick in the cards too far….. doing so, you risk a 600 euro replacement as I experienced………
Edgar Broekema - Réponse
Gently twist the plastic card sideways to create a gap between the display and frame. Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
  • Gently twist the plastic card sideways to create a gap between the display and frame.
  • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
This part must be done very carefully or you can damage the flat cable from display, despite it was under a iron cover.
Cassio Machado - Réponse
Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac. Be sure to stop before the iSight camera, or you may damage it. Be sure to stop before the iSight camera, or you may damage it.
  • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
  • Be sure to stop before the iSight camera, or you may damage it.
Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking. Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
  • Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac. Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac. Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
  • Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
Gently twist the card upward, slightly increasing the space between the display and frame. As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  • Gently twist the card upward, slightly increasing the space between the display and frame.
  • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera.
  • Slide the plastic card toward the center, again stopping just before the iSight camera.
Wedge the plastic card back into the top left corner. Wedge the plastic card back into the top left corner.
  • Wedge the plastic card back into the top left corner.
With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case. If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive. Begin to lift the top of the display up from the frame.
  • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
  • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
  • Begin to lift the top of the display up from the frame.
  • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8"). Hold the display with one hand while using your other hand to unplug the display power cable.
  • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
  • Hold the display with one hand while using your other hand to unplug the display power cable.
It was difficult to remove this connection. I ended up having to gently pull-up vertically a little on the wire side to unsnap it about 1mm and then horizontally wiggle it out.
delacrj2 - Réponse
I had a difficult time removing this connection. I had to lift the wire-side about 1mm before it unsnapped and then carefully wiggle it out horizontally.
delacrj2 - Réponse
Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable. Carefully pull the display data cable from its socket on the logic board. Be sure to pull the display data cable connector straight out of its socket, keeping it parallel to the motherboard, to avoid damaging it.
  • Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable.
  • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket, keeping it parallel to the motherboard, to avoid damaging it.
Lift the display up to a near-vertical position. At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  • Lift the display up to a near-vertical position.
  • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip. If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
  • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
At step 21-22, releasing the adhesive strips from the bottom of the display, I noticed a tab on the outer end of each strip. Pull the tab to remove the whole strip, no need to mess around with the plastic cards!
Lift the display up from the frame and remove it from the iMac. It may be necessary to slowly lift from one side to peel against the remaining adhesive. Be very careful handling the display—it's big, heavy, and made of glass.
  • Lift the display up from the frame and remove it from the iMac.
  • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
  • Be very careful handling the display—it's big, heavy, and made of glass.
  • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
Remove the following five Phillips  screws holding the lower support bracket in place: Four 3.2 mm screws
  • Remove the following five Phillips screws holding the lower support bracket in place:
    • Four 3.2 mm screws
    • One 1.7 mm screw
  • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
Remove the lower support bracket from the iMac enclosure.
  • Remove the lower support bracket from the iMac enclosure.
Remove the following T10 Torx screws securing the hard drive brackets to the iMac:
  • Remove the following T10 Torx screws securing the hard drive brackets to the iMac:
    • Two 21 mm screws
    • One 9 mm screw
    • One 27 mm screw
At step 26, when reassembling, it's super easy to over-tighten the 9mm screw and strip the brass ferrule out of its hole in the plastic bracket (%#*@).
Remove the left and right hard drive brackets from the iMac. Remove the left and right hard drive brackets from the iMac.
  • Remove the left and right hard drive brackets from the iMac.
The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply or any of the exposed solder. Touching it risks a high voltage shock from the many large capacitors attached to the board. Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket. Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket.
  • The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply or any of the exposed solder. Touching it risks a high voltage shock from the many large capacitors attached to the board.
  • Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket.
I would advise that before removing the PSU unit and all other components from the bottom of the case that you remove the 5 screws at the bottom of the display which hold an insulation strip in place.
The guide shows this piece removed, but does not tell you how to remove it.
There will be 5, small J1000 screws. The middle one, which goes over Apple Logo is the shorter one of the 5, all others are the same length. Once this piece is gone removing the components is much easier, and chance of damage lessened.
Jeffrey Gelinas - Réponse
Added to the guide. Thanks for the tip!
Jeff Suovanen -
No need to remove power board and logic board and all other components, just remove the fan and it is quite "easily" accessable to change the RAM. Just need to use the tools to remove the old RAM and carefully install the new RAM.
I just did it without removing the logic or power board
Oleksandr Trokhymchuk - Réponse
Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket. Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket.
  • Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket.
Remove the two 7.2 mm T10 Torx screws securing the power supply to the rear enclosure.
  • Remove the two 7.2 mm T10 Torx screws securing the power supply to the rear enclosure.
    • In newer model iMacs these are 7.2 mm T8 Torx screws.
When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges. Tilt the power supply forward.
  • When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  • Tilt the power supply forward.
When replacing the PSU (on the re-build) take care not to trap the power button cable behind it - I did...
Dave Hallett - Réponse
Pull the power supply slightly up and out from the rear enclosure. Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left. Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
  • Pull the power supply slightly up and out from the rear enclosure.
  • Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
Slide the power supply to the right to clear the screw posts on the rear enclosure. Slide the power supply to the right to clear the screw posts on the rear enclosure.
  • Slide the power supply to the right to clear the screw posts on the rear enclosure.
Rock the power supply forward and remove it from its recess in the rear enclosure. Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board. Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board.
  • Rock the power supply forward and remove it from its recess in the rear enclosure.
  • Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges. Flip the power supply over to access the DC power cable connection behind the logic board.
  • Flip the power supply over to access the DC power cable connection behind the logic board.
  • Squeeze the tab on the back side of the DC power cable connector and pull it straight out of its socket on the back of the logic board.
when pulled the cable, even slightly, the actual female piece that connects to the logic board came off. am i screwed?
Racheal Major - Réponse
You may find it helpful to set the iMac down on its back for the next couple of steps. Use the flat end of a spudger to press the clip on the side of the AC inlet cable connector inward. While pressing on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
  • You may find it helpful to set the iMac down on its back for the next couple of steps.
  • Use the flat end of a spudger to press the clip on the side of the AC inlet cable connector inward.
  • While pressing on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
I didn't disconnect the input cable to the power supply. Because I had the machine lying on its back throughout, I placed it on to the metal bit at the bottom of the machine instead (with a cloth to stop the metal getting scratched). The AC inlet cable was pretty tricky to get un-locked, and the PSU sat on the case fine. It didn't hinder anything else throughout the guide.
I thought from Dave’s comment that I could leave the power supply completely in place, but I was mistaken. In order to remove the hard drive assembly after you remove the center screw in it, you’ll need to at least unscrew it and the HD assembly will slip out. Like Dave said, you don’t need to unplug the AC or PSU, which I left hanging.
Getting power supply to the logic board unplugged is also tricky without unscrewing the two bottom screws. They didn’t make this part easy.
delacrj2 - Réponse
Remove the power supply from the iMac.
  • Remove the power supply from the iMac.
erreur: retirer "la carte d'alimentation" et non" le disque dur" !!!!!
Moreau - Réponse
Gently pull the fan cable connector straight away from its socket on the logic board. Gently pull the fan cable connector straight away from its socket on the logic board.
  • Gently pull the fan cable connector straight away from its socket on the logic board.
Remove the three 10 mm T10 Torx screws securing the fan to the rear enclosure.
  • Remove the three 10 mm T10 Torx screws securing the fan to the rear enclosure.
    • The uppermost screw has a rubber standoff adhered to its head to support the display—leave this in place.
Remove the fan from the iMac. Remove the fan from the iMac.
  • Remove the fan from the iMac.
Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess. The hard drive is still attached by its SATA cable; do not attempt to fully remove it from the iMac yet. The hard drive is still attached by its SATA cable; do not attempt to fully remove it from the iMac yet.
  • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
  • The hard drive is still attached by its SATA cable; do not attempt to fully remove it from the iMac yet.
Use a spudger to disconnect the single SATA cable by prying it gently away from the hard drive. Remove the hard drive assembly from the iMac. Remove the hard drive assembly from the iMac.
  • Use a spudger to disconnect the single SATA cable by prying it gently away from the hard drive.
  • Remove the hard drive assembly from the iMac.
Peel the rubber bumper off one side of the hard drive. Repeat for the other side. When installing a new drive, it's helpful to use double-sided tape to stick the bumpers to your new drive.
  • Peel the rubber bumper off one side of the hard drive.
  • Repeat for the other side.
  • When installing a new drive, it's helpful to use double-sided tape to stick the bumpers to your new drive.
reconnecting the new drive can be a little tricky as the sata connector in the Mac is hard to align. I found that it helps to move the end of the bumpers out of the way, then push them back into position once the drive is connected.
Gareth Jones - Réponse
thats what it did as well, thx for the hint. also i used a plastic spudger to reconnect the plug unto the new drive and leveled it against the speaker casing thats so close to the drive bay
Stef999 - Réponse
Can I install a Samsung 850 EVO 500GB to replace my 1TB 5400rpm disk? and is a seperate thermal sensor/cable needed to prohibit the fan to run at 100% all the time?
Maurits Kühne - Réponse
Yes you can install ANY SATA SSD.
And no … there is no thermal sensor on the drive. You don’t need them on these models.
robert Seith -
Can I install a Seagate FireCuda 2TB to replace my 1TB 5400rpm disk? and is a seperate thermal sensor/cable needed to prohibit the fan to run at 100% all the time?
andrew mudd - Réponse
Did you ever find out if you could replace your 500 GB with that Firecuda? I’m looking at doing that. I need more storage for my 500 GB photos library and don’t want to pay so a ton for the SSD that is big enough.
shippster -
where is the guide for the follow up ?
installing a new hard disk and closing the screen back up.
yog1389 - Réponse
Remove the 7.3 mm T8 Torx screw securing the hard drive tray to the rear enclosure.
  • Remove the 7.3 mm T8 Torx screw securing the hard drive tray to the rear enclosure.
Remove the hard drive tray.
  • Remove the hard drive tray.
Gently pull the right speaker cable connector straight down and out of its socket on the logic board. Gently pull the right speaker cable connector straight down and out of its socket on the logic board.
  • Gently pull the right speaker cable connector straight down and out of its socket on the logic board.
Gently pull the left speaker cable straight out of its socket on the logic board. Gently pull the left speaker cable straight out of its socket on the logic board.
  • Gently pull the left speaker cable straight out of its socket on the logic board.
De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
  • De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
Similarly to the previous step, de-route the SATA and power cables by pulling the braid straight up out of the retaining clip. Similarly to the previous step, de-route the SATA and power cables by pulling the braid straight up out of the retaining clip.
  • Similarly to the previous step, de-route the SATA and power cables by pulling the braid straight up out of the retaining clip.
Peel up the piece of tape connecting the left speaker connector to the SATA power and data cables. Peel up the piece of tape connecting the left speaker connector to the SATA power and data cables.
  • Peel up the piece of tape connecting the left speaker connector to the SATA power and data cables.
Flip up the metal retaining bracket on the FaceTime camera cable connector. Pull the FaceTime camera cable straight out of its socket on the logic board. This is a delicate connector that can be easily damaged.
  • Flip up the metal retaining bracket on the FaceTime camera cable connector.
  • Pull the FaceTime camera cable straight out of its socket on the logic board.
    • This is a delicate connector that can be easily damaged.
Remove the two 4.0 mm T5 Torx screws securing the four antenna connectors to the AirPort/Bluetooth card.
  • Remove the two 4.0 mm T5 Torx screws securing the four antenna connectors to the AirPort/Bluetooth card.
Disconnect all four antenna connectors by prying them straight up from their sockets on the AirPort/Bluetooth card. Disconnect all four antenna connectors by prying them straight up from their sockets on the AirPort/Bluetooth card. Disconnect all four antenna connectors by prying them straight up from their sockets on the AirPort/Bluetooth card.
  • Disconnect all four antenna connectors by prying them straight up from their sockets on the AirPort/Bluetooth card.
Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board. This connector is located on the bottom right edge of the logic board, near the right speaker. Push the cable up and out of the way of the logic board.
  • Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
    • This connector is located on the bottom right edge of the logic board, near the right speaker.
  • Push the cable up and out of the way of the logic board.
Peel off the tape covering the exhaust duct.
  • Peel off the tape covering the exhaust duct.
Remove the following T8 Torx screws securing the exhaust duct to the rear enclosure:
  • Remove the following T8 Torx screws securing the exhaust duct to the rear enclosure:
    • Two 6.2 mm screws
    • Two 4.7 mm screws
At least in the 2017 iMac both of the red screws are missing – removing the orange ones was enough.
Jonathan Rudow - Réponse
Flip the latch on the microphone ZIF connector and pull the cable out of its socket on the logic board. Flip the latch on the microphone ZIF connector and pull the cable out of its socket on the logic board. Flip the latch on the microphone ZIF connector and pull the cable out of its socket on the logic board.
  • Flip the latch on the microphone ZIF connector and pull the cable out of its socket on the logic board.
Remove the four 7.3 mm T8 Torx screws securing the logic board to the rear enclosure.
  • Remove the four 7.3 mm T8 Torx screws securing the logic board to the rear enclosure.
Tilt the top of the logic board away from the rear enclosure. Tilt the top of the logic board away from the rear enclosure.
  • Tilt the top of the logic board away from the rear enclosure.
As the motherboard is left on the first picture, shouldn't it be at the second place ?
Emmanuel - Réponse
When removing and installing the logic board, take care not to damage the delicate microphone ribbon cable at the bottom left.
  • When removing and installing the logic board, take care not to damage the delicate microphone ribbon cable at the bottom left.
  • Lift the logic board straight up and out of the iMac.
  • Be careful not to snag the board on any of the rear enclosure's screw posts.
At step 60, when reinstalling the logic board, check to make sure the I/O ports are flush with the back of the case. It’s easy to end up with a small gap, and if you do, you won’t be able to fully insert USB-C connectors.
Handling the board by the edges, flip the logic board over to access the two RAM modules.
  • Handling the board by the edges, flip the logic board over to access the two RAM modules.
What is the left bottom m.2 terminal?
Daewon - Réponse
Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module. When released, the RAM module will pop up at a slight angle.
  • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
Lift the RAM module to an angle of about 30 degrees and slide it out. When handling the RAM module, touch only the outside edges. Take care not to touch the gold-colored contact points along the bottom edge.
  • Lift the RAM module to an angle of about 30 degrees and slide it out.
  • When handling the RAM module, touch only the outside edges. Take care not to touch the gold-colored contact points along the bottom edge.
  • To install a new RAM module, slide it in place at about the same angle until it is snug, and then swing it downward until the two clips snap into place.
The original RAM module closer to the logic board has a thermal pad adhered to its top side (facing away from the logic board, between the two DIMMs). Peel off and transfer the thermal pad from the original RAM stick to your replacement RAM before you install it in the lower slot.
  • The original RAM module closer to the logic board has a thermal pad adhered to its top side (facing away from the logic board, between the two DIMMs).
  • Peel off and transfer the thermal pad from the original RAM stick to your replacement RAM before you install it in the lower slot.
4 autre(s) ont terminé cette réparation.
Sam Lionheart
Membre depuis le 18/10/2012
314 298 Réputation
1 632 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
117 membres
5 752 tutoriels rédigés
Upgraded to a SSD and maxed the RAM on a 2017 21.5” iMac retina. Perfect instructions. Takes 90-120 minutes for a first-timer. Getting the LCD off is the hardest part… be patient and very careful. Recommend testing everything before putting new adhesive strips on.
Joe - Réponse
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 62
30 derniers jours : 352
Total : 8,160
