Aller au contenu principal
iMac Intel 24" EMC 2111 Display Data Cable Replacement
Ce dont vous avez besoin
  1. iMac Intel 24" EMC 2111 Display Data Cable Replacement, Access Door: étape 1, image 1 de 2 iMac Intel 24" EMC 2111 Display Data Cable Replacement, Access Door: étape 1, image 2 de 2
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
  2. iMac Intel 24" EMC 2111 Display Data Cable Replacement, Front Bezel: étape 2, image 1 de 1
    • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw
  3. iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 3, image 1 de 2 iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 3, image 2 de 2
    • Lay your iMac stand-side down on a flat surface.
    • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
    • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
  4. iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 4, image 1 de 3 iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 4, image 2 de 3 iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 4, image 3 de 3
    • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
    • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
    • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
  5. iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 5, image 1 de 1
    • If necessary, remove the strip of tape covering the microphone cable connector.
    • The microphone connector is located near the inside of top edge of your iMac.
  6. iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 6, image 1 de 3 iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 6, image 2 de 3 iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 6, image 3 de 3
    • Disconnect the microphone cable.
    • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
    • The camera cable connector and socket are delicate and easily bent. Remove with caution.
  7. iMac Intel 24" EMC 2111 Display Data Cable Replacement, Display Assembly: étape 7, image 1 de 2 iMac Intel 24" EMC 2111 Display Data Cable Replacement, Display Assembly: étape 7, image 2 de 2
    • Peel the two highlighted EMI shield tabs off the frame of the LCD.
  8. iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 8, image 1 de 1
    • Remove the two T6 Torx screws securing the display data cable to the logic board.
  9. iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 9, image 1 de 1
    • Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
  10. iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 10, image 1 de 2 iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 10, image 2 de 2
    • Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board.
    • De-route the inverter cable from its location next to the CPU fan.
  11. iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 11, image 1 de 1
    • Before attempting this step, we recommend laying your iMac stand-side down on a table to avoid the display falling down.
    • Remove the eight T8 Torx screws securing the display assembly to the rear case.
    • It is helpful to use a thin magnetized screwdriver to remove these screws.
  12. iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 12, image 1 de 1
    • Remove the display assembly from the iMac.
  13. iMac Intel 24" EMC 2111 Display Data Cable Replacement, Display Data Cable: étape 13, image 1 de 1
    • Remove the two pieces of tape securing the display data cable to the back of the display.
  14. iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 14, image 1 de 1
    • Squeeze the two retaining arms together and pull the display data cable connector out of its socket.
    • Pull the cable parallel to the rear face of the LCD. Pulling upward may damage the cable and/or the LCD.
  15. iMac Intel 24" EMC 2111 Display Data Cable Replacement: étape 15, image 1 de 1
    • Remove the display data cable.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 5,259
