Aller au contenu principal
iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement, Glass Panel: étape 1, image 1 de 3 iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement, Glass Panel: étape 1, image 2 de 3 iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement, Glass Panel: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    Heavy-Duty Suction Cups (Pair)
    $14.95
    J'achète
    • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
    • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
    • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
    • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
  2. iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 2, image 1 de 3 iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 2, image 2 de 3 iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 2, image 3 de 3
    • Gently lift the glass panel perpendicular to the face of the LCD, enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • Don't use the suction cups to carry the glass panel—if either one loses its grip, the panel could fall and break.
    • After setting the glass panel down safely, be sure to release the suction cups, as the suction force over time can crack the glass.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  3. iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement, Display: étape 3, image 1 de 1
    • Remove the eight T10 Torx screws securing the LCD to the outer case.
  4. iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 4, image 1 de 3 iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 4, image 2 de 3 iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 4, image 3 de 3
    • Carefully lay the iMac stand-side down on a flat surface.
    • Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the third picture, we made one out of a bent paperclip.
    • Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
    • After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side. A pencil or pen can be placed under the top edge of the display, parallel to the top edge and extending past the edge of the computer, to keep the first side propped up while lifting the second.
    • Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
  5. iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 5, image 1 de 2 iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 5, image 2 de 2
    • Use a pair of tweezers to pull the vertical sync ribbon cable out of its socket on the LED driver board near the top left corner of your iMac.
    • On some iMacs this may not be a ribbon cable but four separate, very fine and very fragile wires. Be very careful, if the tweezers slip off the plug, you will very likely pull a wire out of the assembly.
  6. iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 6, image 1 de 1
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
  7. iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 7, image 1 de 1
    • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
    • Pull the display data cable connector away from its socket on the logic board.
    • Be very careful when disconnecting this cable as both the cable connector and logic board socket are extremely fragile. When reconnecting the cable later, use as little force as possible.
  8. iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 8, image 1 de 1
    • Lift the display for enough clearance to disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable. The thermal sensor connector socket is very fragile, so be very careful when you connect back the sensor cable.
  9. iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 9, image 1 de 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case.
  10. iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement, Power Supply: étape 10, image 1 de 2 iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement, Power Supply: étape 10, image 2 de 2
    • The next few steps bring your hands close to the exposed face of the power supply. To avoid a high voltage shock from the many large capacitors attached to the board, do not touch the face of the power supply.
    • Disconnect the DC power cable by using your index finger to depress the locking mechanism on the back of the connector while you pull the connector away from its socket on the power supply.
    • Once the locking mechanism has cleared the socket, pull the DC power connector away from the power supply.
  11. iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 11, image 1 de 1
    • Disconnect the AC power inlet cable by depressing the locking mechanism while pulling the connector away from its socket.
  12. iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 12, image 1 de 1
    • Remove the following screws securing the power supply to the outer case:
    • Two fine-thread shouldered T10 Torx
    • One coarse-thread shouldered T10 Torx
    • One short coarse-thread T10 Torx
  13. iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 13, image 1 de 2 iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement: étape 13, image 2 de 2
    • Lift the power supply out of the outer case while gently de-routing it from any wires that may get caught.
    • Two plastic brackets may lift out with the power supply. Their correct orientation is shown in the second picture.
112 autres ont terminé cette réparation.
20 commentaires
Super tutoriel ! Félicitations et merci à son auteur, sans lui je n'aurais pas entrepris de démonter l'iMac... et serait resté avec une machine en panne à remplacer.
Michel T
Michel Teissier - Réponse
That's ok now ! I've had to repair the iMac twice because the Power Supply Unit was also out. At the beginning of the problem, the power button didn't work, but sometimes it worked. For instance if the iMac was stopped for several hours, or days ! Then, it was more and more frequent. I have supposed that some large capacitors on the PSU were too old and wrong. Could it be the reason ?
Many thanks to Ifix-It Europe : they have sent a new PSU very quickly. This 2nd repair took me about 45'.
Best regards
Michel
Excellent walkthrough!
I do now have an issue. When all reassembled I now have now power at all. Suggestions or causes?
Shane Thomas - Réponse
It looks like you’ve made it very easy to follow, but I haven’t started yet!!! Can anyone tell me if these steps are the same for replacing the power supply for a 27" A1316 LED display screen. Thanks.
Fm34b - Réponse
Thanks for the walk through, it worked like a charm!
Jason Halliday - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 34
30 derniers jours : 168
Total : 103,075
