Introduction
Use this guide to replace a faulty SD Board.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Grasp the SD board cable connector with a pair of tweezers and pull it straight away from its socket on the SD board.
4 autres ont terminé cette réparation.
Un commentaire
One must consider, the USP based card adapter is like five dollars.
When I tell customers this, they usually get that instead of paying me $100 plus parts to repair it
