Introduction
This guide covers the disassembly of the iON SnapCam 1045 battery.
Pièces
Aucune pièce nécessaire.
Detach the magnetic  clip from the bottom  of the camera.
  • Detach the magnetic clip from the bottom of the camera.
  • The magnetic clip gets in the way of disassembly because it constantly spins and therefore a distraction so it is imperative to detach.
Ajouter un commentaire
Use a spudger to  gently detach  the  memory card and USB slot cover.
  • Use a spudger to gently detach the memory card and USB slot cover.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use a Phillips #000 Screwdriver to  loosen the 0.008 mm screw  located between the USB and memory card slots.
  • Use a Phillips #000 Screwdriver to loosen the 0.008 mm screw located between the USB and memory card slots.
  • This screw is really tiny and can easily fall off and get lost! Make use of a magnetic mat to hold it in place or better still put the magnetic clip to use for keeping the screw safe.
Once again use the spudger to gently open the encasement. The case is a little fragile and forceful entry could lead to damage of the plastic case. Thread carefully.
  • Once again use the spudger to gently open the encasement.
  • The case is a little fragile and forceful entry could lead to damage of the plastic case. Thread carefully.
  • The Battery can be safely detached and replaced.
Olakunle
Membre depuis le 11/11/2017
102 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S3-G3, Wilson Fall 2017 Membre de l'équipe IUPUI, Team S3-G3, Wilson Fall 2017
IUPUI-WILSON-F17S3G3
3 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 104
