Remove any external skins placed on the device. To do so, simply lift up and peel to remove. Remove any external skins placed on the device. To do so, simply lift up and peel to remove.
  • Remove any external skins placed on the device. To do so, simply lift up and peel to remove.
Ajouter un commentaire
Firmly pull on the back clip in order to remove.
  • Firmly pull on the back clip in order to remove.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use a Phillips head screwdriver to remove the four 4mm PH00 screws located on the sides of the device. All screws are located under each of the grey covers for the microSD card and the microUSB insert.
  • Use a Phillips head screwdriver to remove the four 4mm PH00 screws located on the sides of the device. All screws are located under each of the grey covers for the microSD card and the microUSB insert.
Grab a metal or plastic opening tool and insert it into the middle slot on the bottom of the camera and lightly pry open. Locate the camera lens in the bottom left-hand corner of the picture which can be replaced by replacing the entire cover. The back of the cover is also shown. The camera is now located in the top right-hand corner of the picture. Locate the camera lens in the bottom left-hand corner of the picture which can be replaced by replacing the entire cover. The back of the cover is also shown. The camera is now located in the top right-hand corner of the picture.
  • Grab a metal or plastic opening tool and insert it into the middle slot on the bottom of the camera and lightly pry open.
  • Locate the camera lens in the bottom left-hand corner of the picture which can be replaced by replacing the entire cover. The back of the cover is also shown. The camera is now located in the top right-hand corner of the picture.
Using the nylon spudger, pop up the edges of the motherboard.
  • Using the nylon spudger, pop up the edges of the motherboard.
With the Micro USB port exposed,  part can be replaced with advanced soldering and circuitry.
  • With the Micro USB port exposed, part can be replaced with advanced soldering and circuitry.
Baleigh Hance
Membre depuis le 20/11/2017
101 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S22-G4, Bayer Fall 2017 Membre de l'équipe IUPUI, Team S22-G4, Bayer Fall 2017
IUPUI-BAYER-F17S22G4
5 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 25
