Aller au contenu principal
iON SnapCam 1046 Lite Capture Button Replacement
Ce dont vous avez besoin
  1. iON SnapCam 1046 Lite Capture Button Replacement, Camera Lens and Cover: étape 1, image 1 de 2 iON SnapCam 1046 Lite Capture Button Replacement, Camera Lens and Cover: étape 1, image 2 de 2
    • Remove any external skins placed on the device. To do so, simply lift up and peel to remove.
  2. iON SnapCam 1046 Lite Capture Button Replacement: étape 2, image 1 de 1
    • Firmly pull on the back clip in order to remove.
  3. iON SnapCam 1046 Lite Capture Button Replacement: étape 3, image 1 de 1
    • Use a Phillips head screwdriver to remove the four 4mm PH00 screws located on the sides of the device. All screws are located under each of the grey covers for the microSD card and the microUSB insert.
  4. iON SnapCam 1046 Lite Capture Button Replacement: étape 4, image 1 de 3 iON SnapCam 1046 Lite Capture Button Replacement: étape 4, image 2 de 3 iON SnapCam 1046 Lite Capture Button Replacement: étape 4, image 3 de 3
    • Grab a metal or plastic opening tool and insert it into the middle slot on the bottom of the camera and lightly pry open.
    • Locate the camera lens in the bottom left-hand corner of the picture which can be replaced by replacing the entire cover. The back of the cover is also shown. The camera is now located in the top right-hand corner of the picture.
  5. iON SnapCam 1046 Lite Capture Button Replacement, Capture Button: étape 5, image 1 de 2 iON SnapCam 1046 Lite Capture Button Replacement, Capture Button: étape 5, image 2 de 2
    • Remove the motherboard by pulling it from the edges as circled.
  6. iON SnapCam 1046 Lite Capture Button Replacement: étape 6, image 1 de 1
    • Replace capture button with advanced soldering and circuitry (circled in red).
Once the capture button has been replaced, reassemble the iON SnapCam Lite by following these steps in reverse order.
Ahmad Syamil Ali
Membre depuis le 11/20/17
101 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S22-G4, Bayer Fall 2017 Membre de l'équipe IUPUI, Team S22-G4, Bayer Fall 2017
IUPUI-BAYER-F17S22G4
5 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 137
