Aller au contenu principal
iPad Air Wi-Fi Case Button/Cable Replacement
Ce dont vous avez besoin
  1. iPad Air Wi-Fi Case Button/Cable Replacement, iOpener Heating: étape 1, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement, iOpener Heating: étape 1, image 2 de 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad Air Wi-Fi Case Button/Cable Replacement: étape 2, image 1 de 1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad Air Wi-Fi Case Button/Cable Replacement: étape 3, image 1 de 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad Air Wi-Fi Case Button/Cable Replacement, Alternate iOpener heating method: étape 4, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement, Alternate iOpener heating method: étape 4, image 2 de 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad Air Wi-Fi Case Button/Cable Replacement, Front Panel: étape 5, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement, Front Panel: étape 5, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement, Front Panel: étape 5, image 3 de 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. iPad Air Wi-Fi Case Button/Cable Replacement: étape 6, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 6, image 2 de 2
    • Handling it by the tag, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for at least a minute to soften the adhesive beneath the glass.
  7. iPad Air Wi-Fi Case Button/Cable Replacement: étape 7, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 7, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 7, image 3 de 3
    • While the iPad looks uniform from the outside, there are delicate components under the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Front-facing camera
    • Antennas
    • Display cables
  8. iPad Air Wi-Fi Case Button/Cable Replacement, Anti-Clamp instructions: étape 8, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement, Anti-Clamp instructions: étape 8, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement, Anti-Clamp instructions: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Clamp
    $24.95
    J'achète
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  9. iPad Air Wi-Fi Case Button/Cable Replacement: étape 9, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 9, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 9, image 3 de 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  10. iPad Air Wi-Fi Case Button/Cable Replacement: étape 10, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 10, image 2 de 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  11. iPad Air Wi-Fi Case Button/Cable Replacement: étape 11, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 11, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 11, image 3 de 3
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
    • If your iPad's screen is badly cracked, covering it with a smooth layer of clear packing tape may help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
  12. iPad Air Wi-Fi Case Button/Cable Replacement: étape 12, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 12, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 12, image 3 de 3
    • Place an opening pick in the gap opened by the suction cup.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
    • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
  13. iPad Air Wi-Fi Case Button/Cable Replacement: étape 13, image 1 de 1
    • Reheat and replace the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  14. iPad Air Wi-Fi Case Button/Cable Replacement: étape 14, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 14, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 14, image 3 de 3
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
  15. iPad Air Wi-Fi Case Button/Cable Replacement: étape 15, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 15, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 15, image 3 de 3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  16. iPad Air Wi-Fi Case Button/Cable Replacement: étape 16, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 16, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 16, image 3 de 3
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
    • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out just a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
  17. iPad Air Wi-Fi Case Button/Cable Replacement: étape 17, image 1 de 1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  18. iPad Air Wi-Fi Case Button/Cable Replacement: étape 18, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 18, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 18, image 3 de 3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  19. iPad Air Wi-Fi Case Button/Cable Replacement: étape 19, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 19, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 19, image 3 de 3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • The third image shows where the front-facing camera and housing are in the iPad.
    • Avoid sliding the opening pick over the front facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front facing camera.
  20. iPad Air Wi-Fi Case Button/Cable Replacement: étape 20, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 20, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 20, image 3 de 3
    • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
  21. iPad Air Wi-Fi Case Button/Cable Replacement: étape 21, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 21, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 21, image 3 de 3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, and then slide it to the corner of the iPad to finish cutting the adhesive on that edge.
  22. iPad Air Wi-Fi Case Button/Cable Replacement: étape 22, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 22, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 22, image 3 de 3
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  23. iPad Air Wi-Fi Case Button/Cable Replacement: étape 23, image 1 de 1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining side of the iPad—along the volume and lock buttons.
  24. iPad Air Wi-Fi Case Button/Cable Replacement: étape 24, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 24, image 2 de 2
    • Slide the opening pick around the top right corner of the iPad, releasing the adhesive there.
    • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
  25. iPad Air Wi-Fi Case Button/Cable Replacement: étape 25, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 25, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 25, image 3 de 3
    • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
  26. iPad Air Wi-Fi Case Button/Cable Replacement: étape 26, image 1 de 1
    • Leave the opening picks in place, and set the reheated iOpener on the home button end of the iPad.
  27. iPad Air Wi-Fi Case Button/Cable Replacement: étape 27, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 27, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 27, image 3 de 3
    • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
    • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
    • The third image shows the two antennas and the home button cavity in the lower case of the iPad.
    • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
  28. iPad Air Wi-Fi Case Button/Cable Replacement: étape 28, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 28, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 28, image 3 de 3
    • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
    • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
    • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
    • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
    • Leave the pick in place before moving on.
  29. iPad Air Wi-Fi Case Button/Cable Replacement: étape 29, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 29, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 29, image 3 de 3
    • Take a new pick and slip it in to the right of the previous pick.
    • Slide across the home button and right-hand antenna using only the very tip to remove the adhesive.
  30. iPad Air Wi-Fi Case Button/Cable Replacement: étape 30, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 30, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 30, image 3 de 3
    • With the adhesive loosened, you can now insert the pick near the right-hand corner. Slide the pick to the left, and stop just short of the Home button.
    • Just like with the left antenna, only slide from the outer edge toward the center. Reversing this direction may damage the antenna.
  31. iPad Air Wi-Fi Case Button/Cable Replacement: étape 31, image 1 de 1
    • Reheat and reapply the iOpener to the volume control side of the iPad.
  32. iPad Air Wi-Fi Case Button/Cable Replacement: étape 32, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 32, image 2 de 2
    • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • On the side of the iPad opposite the volume controls, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along the display cable edge.
    • If you encounter a significant amount of resistance, leave the picks in place, reheat, and reapply the iOpener to the problem areas.
  33. iPad Air Wi-Fi Case Button/Cable Replacement: étape 33, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 33, image 2 de 2
    • Lift slowly and gently to further detach the adhesive along the display cable edge.
  34. iPad Air Wi-Fi Case Button/Cable Replacement: étape 34, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 34, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 34, image 3 de 3
    • While supporting the front panel glass, use an opening pick to cut the last of the adhesive.
    • Be very careful not to cut or damage any of the display cables.
  35. iPad Air Wi-Fi Case Button/Cable Replacement: étape 35, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 35, image 2 de 2
    • Once all of the adhesive has been separated, open the glass panel like a page in a book and rest it on your workspace.
    • During reassembly, clean the remains of the adhesive from the case (and the front glass if you are re-using it) with isopropyl alcohol, and replace the adhesive using our display adhesive application guide and pre-cut adhesive strips.
    • It's easy to pinch a flex cable between the front glass and the iPad's frame during reassembly. Be mindful of the flex cables and make sure they gently fold and tuck under the frame. If the folds in a flex cable are pressed completely flat, it may be damaged beyond repair.
  36. iPad Air Wi-Fi Case Button/Cable Replacement, LCD: étape 36, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement, LCD: étape 36, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement, LCD: étape 36, image 3 de 3
    • Remove any tape obscuring the LCD screws.
  37. iPad Air Wi-Fi Case Button/Cable Replacement: étape 37, image 1 de 1
    • Remove the following Phillips screws securing the LCD.
    • Three 4.0 mm screws
    • One 4.8 mm screw
  38. iPad Air Wi-Fi Case Button/Cable Replacement: étape 38, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 38, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 38, image 3 de 3
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
  39. iPad Air Wi-Fi Case Button/Cable Replacement: étape 39, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 39, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 39, image 3 de 3
    Battery Blocker
    $3.99
    J'achète
    • Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
    • To reduce the risk of a short, you can insert a battery blocker or a modified opening pick to disconnect the battery.
    • Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage.
    • Slide the battery blocker underneath the battery connector area of the logic board, and leave it in place while you work.
    • If you are having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery.
  40. iPad Air Wi-Fi Case Button/Cable Replacement: étape 40, image 1 de 1
    • Remove the three 1.4 mm Phillips screws from the display cable bracket.
  41. iPad Air Wi-Fi Case Button/Cable Replacement: étape 41, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 41, image 2 de 2
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
  42. iPad Air Wi-Fi Case Button/Cable Replacement: étape 42, image 1 de 1
    • Remove the LCD.
  43. iPad Air Wi-Fi Case Button/Cable Replacement, Front Panel Assembly: étape 43, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement, Front Panel Assembly: étape 43, image 2 de 2
    • Remove any tape covering the home button ribbon cable connector.
  44. iPad Air Wi-Fi Case Button/Cable Replacement: étape 44, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 44, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 44, image 3 de 3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable horizontally out of the ZIF connector.
  45. iPad Air Wi-Fi Case Button/Cable Replacement: étape 45, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 45, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 45, image 3 de 3
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  46. iPad Air Wi-Fi Case Button/Cable Replacement: étape 46, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 46, image 2 de 2
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
  47. iPad Air Wi-Fi Case Button/Cable Replacement: étape 47, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 47, image 2 de 2
    Polyimide Tape
    $9.99
    J'achète
    • Remove the front panel assembly.
    • During reassembly, wipe any dust or fingerprints off of the inside of the front panel assembly to ensure a clean display.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  48. iPad Air Wi-Fi Case Button/Cable Replacement, Right Antenna: étape 48, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement, Right Antenna: étape 48, image 2 de 2
    • Insert a spudger under the antenna cable closest to the edge of the iPad and lift upward to disconnect the antenna cable connector.
  49. iPad Air Wi-Fi Case Button/Cable Replacement: étape 49, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 49, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 49, image 3 de 3
    • There are two large pieces of tape wrapped around the right antenna cable, securing it to the rear case.
    • Peel the tape up from the rear case.
    • While peeling the antenna tape up, leave it in place on the antenna cable to aid with reassembly.
  50. iPad Air Wi-Fi Case Button/Cable Replacement: étape 50, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 50, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 50, image 3 de 3
    • The antenna cable is anchored to the speaker with a small metal bracket. The bracket is permanently crimped to the antenna and adhered to the speaker enclosure.
    • Carefully insert an opening pick between the speaker enclosure and the antenna cable bracket.
    • Slide the pick toward the home button to cut the adhesive.
    • Push the bracket away from the speaker until it clears the tape underneath.
  51. iPad Air Wi-Fi Case Button/Cable Replacement: étape 51, image 1 de 1
    • Remove the following Phillips #000 screws securing the right antenna:
    • One 2.3 mm screw
    • Two 1.4 mm screws
  52. iPad Air Wi-Fi Case Button/Cable Replacement: étape 52, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 52, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 52, image 3 de 3
    • Insert the flat end of a spudger between the antenna and the speaker assembly.
    • Slide the spudger toward the home button to cut the foam adhesive securing the antenna.
  53. iPad Air Wi-Fi Case Button/Cable Replacement: étape 53, image 1 de 1
    • Remove the right antenna from the iPad.
  54. iPad Air Wi-Fi Case Button/Cable Replacement, Right Speaker: étape 54, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement, Right Speaker: étape 54, image 2 de 2
    • Insert a spudger under the left antenna cable and lift upward to disconnect the antenna cable connector.
  55. iPad Air Wi-Fi Case Button/Cable Replacement: étape 55, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 55, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 55, image 3 de 3
    • There are five pieces of tape wrapped around the left antenna cable covering the right speaker cable connector.
    • Fold the antenna cable out of the way.
  56. iPad Air Wi-Fi Case Button/Cable Replacement: étape 56, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 56, image 2 de 2
    • A bend in the speaker cable makes it difficult to peel the tape up from the end.
    • Instead, grip the tape just under the speaker and peel it down, away from the edge of the case.
    • Be careful with your tweezers—only grab and peel the tape, and not the cable beneath.
  57. iPad Air Wi-Fi Case Button/Cable Replacement: étape 57, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 57, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 57, image 3 de 3
    • Peel the tape toward the home button to uncover the speaker cable connector.
  58. iPad Air Wi-Fi Case Button/Cable Replacement: étape 58, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 58, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 58, image 3 de 3
    • Use the pointed end of a spudger to flip up the retaining flap on the right speaker cable connector.
    • Slide the speaker cable straight out of its ZIF connector.
  59. iPad Air Wi-Fi Case Button/Cable Replacement: étape 59, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 59, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 59, image 3 de 3
    • Remove the tape holding the speaker to the rear case.
  60. iPad Air Wi-Fi Case Button/Cable Replacement: étape 60, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 60, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 60, image 3 de 3
    • Carefully peel the LCD buffer tape up off of the rear case.
  61. iPad Air Wi-Fi Case Button/Cable Replacement: étape 61, image 1 de 1
    • Remove the 2.2 mm Phillips #000 screw securing the speaker to the rear case.
  62. iPad Air Wi-Fi Case Button/Cable Replacement: étape 62, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 62, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 62, image 3 de 3
    • Insert a fingernail or the flat end of a spudger in the groove in the speaker housing, near the corner of the rear case.
    • Pull the speaker down, away from the corner of the case.
  63. iPad Air Wi-Fi Case Button/Cable Replacement: étape 63, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 63, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 63, image 3 de 3
    • Use a spudger to help pull the speaker out from under the edge of the rear case.
    • Remove the right speaker from the iPad.
  64. iPad Air Wi-Fi Case Button/Cable Replacement, Upper Component Cable Bracket: étape 64, image 1 de 1
    • Remove the three 1.4 mm Phillips #000 screws securing the upper component cable bracket.
  65. iPad Air Wi-Fi Case Button/Cable Replacement: étape 65, image 1 de 1
    • Remove the upper component cable bracket.
    • If you have the Wi-Fi/Cellular model, your iPad will look slightly different and will require the removal of two additional screws to access components covered by this bracket.
  66. iPad Air Wi-Fi Case Button/Cable Replacement, Logic Board: étape 66, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement, Logic Board: étape 66, image 2 de 2
    • There are two remaining pieces of tape securing the left antenna cable to the rear case.
  67. iPad Air Wi-Fi Case Button/Cable Replacement: étape 67, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 67, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 67, image 3 de 3
    • Push the bracket away from the speaker until it is clear of the tape underneath.
  68. iPad Air Wi-Fi Case Button/Cable Replacement: étape 68, image 1 de 1
    • Remove the following Phillips #000 screws:
    • Two 1.4 mm screws
    • One 2.3 mm screw
  69. iPad Air Wi-Fi Case Button/Cable Replacement: étape 69, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 69, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 69, image 3 de 3
  70. iPad Air Wi-Fi Case Button/Cable Replacement: étape 70, image 1 de 1
    • Remove the left antenna from the iPad.
  71. iPad Air Wi-Fi Case Button/Cable Replacement: étape 71, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 71, image 2 de 2
    • Remove the tape covering the left speaker cable connector.
  72. iPad Air Wi-Fi Case Button/Cable Replacement: étape 72, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 72, image 2 de 2
    • Use the pointed end of a spudger to flip up the retaining flap on the left speaker cable connector.
  73. iPad Air Wi-Fi Case Button/Cable Replacement: étape 73, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 73, image 2 de 2
  74. iPad Air Wi-Fi Case Button/Cable Replacement: étape 74, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 74, image 2 de 2
  75. iPad Air Wi-Fi Case Button/Cable Replacement: étape 75, image 1 de 1
  76. iPad Air Wi-Fi Case Button/Cable Replacement: étape 76, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 76, image 2 de 2
    • Gently fold the left speaker ribbon cable up so that it will clear the battery when you slide the speaker enclosure out.
  77. iPad Air Wi-Fi Case Button/Cable Replacement: étape 77, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 77, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 77, image 3 de 3
  78. iPad Air Wi-Fi Case Button/Cable Replacement: étape 78, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 78, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 78, image 3 de 3
    • Remove the left speaker from the iPad.
  79. iPad Air Wi-Fi Case Button/Cable Replacement: étape 79, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 79, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 79, image 3 de 3
    • Use the flat end of a spudger to disconnect the front-facing camera connector from the logic board.
    • Pry up only on the connector—not on the socket itself.
    • Fold the front-facing camera cable out of the way.
    • There is a bit of conductive adhesive between the gold-colored cable contacts. Be sure to apply pressure to readhere these contacts during reassembly.
  80. iPad Air Wi-Fi Case Button/Cable Replacement: étape 80, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 80, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 80, image 3 de 3
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from the logic board.
    • Fold the rear-facing camera cable out of the way.
  81. iPad Air Wi-Fi Case Button/Cable Replacement: étape 81, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 81, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 81, image 3 de 3
    • Use the flat end of a spudger to disconnect the headphone jack connector from the logic board.
    • Newer iPad units have a loop of tape connecting this connector to its socket on the the logic board. This tape must be cut in order to disconnect the headphone jack.
    • Fold the headphone jack cable out of the way.
  82. iPad Air Wi-Fi Case Button/Cable Replacement: étape 82, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 82, image 2 de 2
    • Use the flat end of a spudger to disconnect the microphone cable connector from the logic board.
  83. iPad Air Wi-Fi Case Button/Cable Replacement: étape 83, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 83, image 2 de 2
    • Remove any tape covering the upper button assembly cable connector.
  84. iPad Air Wi-Fi Case Button/Cable Replacement: étape 84, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 84, image 2 de 2
    • Use the pointed end of a spudger to flip up the retaining flap on the upper button assembly cable connector.
  85. iPad Air Wi-Fi Case Button/Cable Replacement: étape 85, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 85, image 2 de 2
    • Slide the upper button assembly cable straight out of its ZIF connector.
  86. iPad Air Wi-Fi Case Button/Cable Replacement: étape 86, image 1 de 1
    • Remove the two 3.3 mm Phillips #000 screws securing the Lightning port.
    • To find these screws, hold the iPad vertically and look down at the Lightning port.
  87. iPad Air Wi-Fi Case Button/Cable Replacement: étape 87, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 87, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 87, image 3 de 3
    • In the next steps, you will use an iOpener to apply heat to the rear case of the iPad to soften adhesive holding the logic board in place.
    • As you reheat and place the iOpener in each of the indicated locations, leave it in place for at least a minute to soften the adhesive through the rear case.
    • The adhesive is in the form of six pieces of black foam tape—refer to this step as you work at heating and prying to keep track of where each piece is located.
  88. iPad Air Wi-Fi Case Button/Cable Replacement: étape 88, image 1 de 1
    • Place a heated iOpener over the rear-facing camera end of the iPad, and let it sit for at least a minute to soften the adhesive through the rear case.
    • More time won't hurt, but you may need to reheat your iOpener and reapply it if you leave it on the rear case for too long.
  89. iPad Air Wi-Fi Case Button/Cable Replacement: étape 89, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 89, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 89, image 3 de 3
    • As you complete the next few steps, prying adhesive securing the logic board in place, always start by testing gently to see if the adhesive is softened. If not, reheat the iOpener and reapply it to the back of the rear case.
    • Carefully insert an opening pick under the logic board, between the front-facing camera and the battery.
    • Slide the pick toward the front-facing camera connector, and stop at the bend in the logic board.
  90. iPad Air Wi-Fi Case Button/Cable Replacement: étape 90, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 90, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 90, image 3 de 3
    • Slide an opening pick under the logic board from the front-facing camera to the rear facing camera.
  91. iPad Air Wi-Fi Case Button/Cable Replacement: étape 91, image 1 de 1
    • Place a heated iOpener along the bottom edge of the iPad.
    • Again, let the iOpener sit for at least a minute to soften the adhesive through the rear case.
  92. iPad Air Wi-Fi Case Button/Cable Replacement: étape 92, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 92, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 92, image 3 de 3
    • The Lightning connector cable is stuck to the case with some adhesive. To detach the adhesive you will be sliding an opening pick between the cable and the case. Be very careful not to cut the Lightning connector cable itself.
    • Insert an opening pick under the Lightning cable where it meets the logic board.
    • Slide the pick down and around the bend in the cable.
  93. iPad Air Wi-Fi Case Button/Cable Replacement: étape 93, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 93, image 2 de 2
    • Continue to slide the opening pick under the cable, stopping before the cable bends to the Lightning connector.
    • Move slowly and carefully. If the opening pick does not slide easily, apply more heat and try again. If you use excessive force, you will likely slip and sever the Lightning connector cable.
  94. iPad Air Wi-Fi Case Button/Cable Replacement: étape 94, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 94, image 2 de 2
    • Finally, slide the opening pick between the battery and the Lightning connector itself to separate the last of the adhesive underneath the cable.
  95. iPad Air Wi-Fi Case Button/Cable Replacement: étape 95, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 95, image 2 de 2
    • Pull the Lightning connector straight out of its recess in the rear case.
  96. iPad Air Wi-Fi Case Button/Cable Replacement: étape 96, image 1 de 1
    • Place a heated iOpener on the left side of the rear case, where the logic board is adhered.
    • Let the iOpener sit for at least a minute to soften the adhesive through the rear case.
  97. iPad Air Wi-Fi Case Button/Cable Replacement: étape 97, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 97, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 97, image 3 de 3
    • Insert a plastic opening tool in the rectangular gap in the upper area of the logic board, and pry the logic board up from the rear case.
    • While keeping the opening tool underneath the logic board, slide it down the length of the gap to free the upper end of the logic board from the adhesive.
  98. iPad Air Wi-Fi Case Button/Cable Replacement: étape 98, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 98, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 98, image 3 de 3
    • Pry up the logic board at the lower edge of the rectangular gap, near the EMI shield.
    • Lift the end of the logic board slowly. If you encounter significant resistance, stop prying and reapply the iOpener.
  99. iPad Air Wi-Fi Case Button/Cable Replacement: étape 99, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 99, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 99, image 3 de 3
    • Slide an opening pick under the logic board between it and the battery.
    • Slide the pick from the base to the center of the logic board to cut the adhesive.
    • Take care not to cut the battery with the opening pick; a punctured battery can be very dangerous. If you encounter resistance, reheat and reapply the iOpener.
  100. iPad Air Wi-Fi Case Button/Cable Replacement: étape 100, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 100, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 100, image 3 de 3
    • Slide the pick up the length of the logic board.
    • Once the adhesive has been cut, pry the battery side of the logic board upward off of the rear case.
  101. iPad Air Wi-Fi Case Button/Cable Replacement: étape 101, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 101, image 2 de 2
    • Continue to lift the logic board along the edge nearest the battery, until you can get an opening pick against the far edge of the logic board.
    • Cut any adhesive holding the outer edge of the logic board to the rear case.
  102. iPad Air Wi-Fi Case Button/Cable Replacement: étape 102, image 1 de 1
    • Remove the logic board from the iPad.
  103. iPad Air Wi-Fi Case Button/Cable Replacement, Case Button/Cable: étape 103, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement, Case Button/Cable: étape 103, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement, Case Button/Cable: étape 103, image 3 de 3
    • Slide a plastic opening tool under the rear facing camera and pry upward to free it from the adhesive securing it to the rear case.
  104. iPad Air Wi-Fi Case Button/Cable Replacement: étape 104, image 1 de 1
    • Remove the rear-facing camera.
  105. iPad Air Wi-Fi Case Button/Cable Replacement: étape 105, image 1 de 1
    • Remove the two 2.3 mm Phillips #000 screws from the power button cable bracket.
  106. iPad Air Wi-Fi Case Button/Cable Replacement: étape 106, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 106, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 106, image 3 de 3
    • Carefully insert an opening pick between the button ribbon cable and the edge of the case.
    • Slide the pick along the length of the cable, stopping at the corner of the case.
    • Go slowly and carefully—if you slip, you could cut the ribbon cable.
  107. iPad Air Wi-Fi Case Button/Cable Replacement: étape 107, image 1 de 1
    • Use the tip of a spudger to push the power button into the rear case from the outside.
  108. iPad Air Wi-Fi Case Button/Cable Replacement: étape 108, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 108, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 108, image 3 de 3
    • With the power button cable bracket loosened, peel it off of the rear case with a set of tweezers and move it out of the way.
    • Do not attempt to remove the power button cable bracket or cable from the iPad, as it is still attached to the rest of the button cable assembly.
    • Push the power button into the case and remove it from the iPad.
  109. iPad Air Wi-Fi Case Button/Cable Replacement: étape 109, image 1 de 1
    • Remove the three 2.3 mm Phillips #000 screws from the button cable bracket.
  110. iPad Air Wi-Fi Case Button/Cable Replacement: étape 110, image 1 de 1
    • Place a heated iOpener on the upper left corner of the rear case to loosen the button bracket's adhesive.
  111. iPad Air Wi-Fi Case Button/Cable Replacement: étape 111, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 111, image 2 de 2
    • Insert an opening pick under the far right corner of the button bracket, between it and the rear case.
    • Slide the pick around the corner to loosen the adhesive—but do not cut any further, or you may damage the button cables.
  112. iPad Air Wi-Fi Case Button/Cable Replacement: étape 112, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 112, image 2 de 2
    • Use the flat end of a spudger to pry in the gap made by the opening pick, lifting the bracket off of the adhesive.
  113. iPad Air Wi-Fi Case Button/Cable Replacement: étape 113, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 113, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 113, image 3 de 3
    • With a set of tweezers, flip the front end of the button bracket up to allow access to the rest of the button ribbon cable.
    • Do not remove the bracket entirely—it is still attached to the ribbon cable. Be very careful in moving the bracket, or you may tear the fine offshoots of the ribbon cable.
  114. iPad Air Wi-Fi Case Button/Cable Replacement: étape 114, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 114, image 2 de 2
    • Gently lift the connector end of the cable slightly off the rear case.
    • Be very careful not to sever the small offshoot cables leading to the volume buttons.
  115. iPad Air Wi-Fi Case Button/Cable Replacement: étape 115, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 115, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 115, image 3 de 3
    • Slide the point of a spudger under the ribbon cable near the button cables to free it from the adhesive holding it to the rear case.
  116. iPad Air Wi-Fi Case Button/Cable Replacement: étape 116, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 116, image 2 de 2
    • Lift the button assembly carefully out of the rear case.
    • It may be useful to use a set of tweezers to lift the connector end of the cable.
  117. iPad Air Wi-Fi Case Button/Cable Replacement: étape 117, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 117, image 2 de 2
    • Use a set of tweezers to remove the rotation lock/mute switch from the rear case.
    • Note the orientation for reassembly: the small gray tab should line up with the groove in the rear case.
  118. iPad Air Wi-Fi Case Button/Cable Replacement: étape 118, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 118, image 2 de 2
    • Use the point of an opening pick to pry the rotation lock/mute switch end of the button cable off of the button bracket.
  119. iPad Air Wi-Fi Case Button/Cable Replacement: étape 119, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 119, image 2 de 2
    • In the place of an opening pick, it may be helpful to remove the rotation lock/mute switch using a set of tweezers.
  120. iPad Air Wi-Fi Case Button/Cable Replacement: étape 120, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 120, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 120, image 3 de 3
    • Use one tine of a set of tweezers to peel the mechanical buttons off of the volume button covers.
    • Remove the button covers.
    • Note the orientation for reassembly.
  121. iPad Air Wi-Fi Case Button/Cable Replacement: étape 121, image 1 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 121, image 2 de 3 iPad Air Wi-Fi Case Button/Cable Replacement: étape 121, image 3 de 3
    • Use one tine of a set of tweezers to pry the sleep/power button up from its bracket.
  122. iPad Air Wi-Fi Case Button/Cable Replacement: étape 122, image 1 de 2 iPad Air Wi-Fi Case Button/Cable Replacement: étape 122, image 2 de 2
    • Remove the sleep/power button from the bracket.
21 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
465 602 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 718 tutoriels rédigés
2 commentaires
This guide was absolutely invaluable. I am v. grateful to Sam for posting it. I ran into two problems implementing it.
One, I have an ongoing problem re-attaching the glass to the iPad with the ribbon cables failing to slide smoothly into the case, making the seal of the glass on the right side problematic. Any tips/tricks here would be welcome.
Second, the iPad Air now refuses to charge. Attaching a power cable does nothing. I suspect that I have may have mixed up a couple of screws in reassembly or at least that is what I have understood from reading this thread ipad does not charge after screen replace Steeling my nerve for another go at it.
Steve Song - Réponse
For the record, it was mixing up two screws in re-assembly that caused the iPad Air to stop charging. I reversed my steps, unscrewed everything and meticulously examined each screw placement. Turns out, I accidentally used a slightly longer screw in one of the three screws holding down the screen ribbon cable connector. Sigh... all good now.
Steve Song -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 35
Total : 39,931
