Outils recommandés dans ce démontage
Introduction
This is the teardown for a Clamcase for iPad 2.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre iPad ClamCase, utilisez notre manuel de réparation.
You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other. Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
  • You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other.
  • Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
  • This will reveal the 6 screws that attach the upper cover to the keyboard cover.
Ajouter un commentaire
Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side. Use  the T6 Torx screwdriver to unscrew the remaining 4 screws.
  • Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side.
  • Use the T6 Torx screwdriver to unscrew the remaining 4 screws.
Turn the keyboard cover over so the bottom is facing up.  Manually remove the thin black covering that is attached to the bottom. Be patient, the thin black covering might be really stuck to the bottom.
  • Turn the keyboard cover over so the bottom is facing up. Manually remove the thin black covering that is attached to the bottom.
  • Be patient, the thin black covering might be really stuck to the bottom.
Once the thin black covering is removed, you will see 15 screws.
  • Once the thin black covering is removed, you will see 15 screws.
  • Use the T6 Torx screwdriver to remove the screws.
Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
  • Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
You are done.
  • You are done.
Izmet Barranco
Membre depuis le 12/12/2012
213 Réputation
1 tutoriel rédigé
Awesome! I used this guide to disassemble my clam case and repair some nonfunctional keys. Thanks!
justin duff - Réponse
Thanks for the dis-assembly guide. Justin, what did you have to do to fix the keys that were not working. I have on with a few keys not working, not even intermittently.
dick haynes - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 26
Total : 6,186
