Introduction
Upgrade your storage with a new hard drive.
Pièces
Aucune pièce nécessaire.
Before opening your iPod, ensure that the hold switch is in the locked position.
  • Before opening your iPod, ensure that the hold switch is in the locked position.
Ajouter un commentaire
Opening the iPod can be challenging; don't get discouraged if it takes you a few tries to get the iPod to open.
  • Opening the iPod can be challenging; don't get discouraged if it takes you a few tries to get the iPod to open.
  • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
Continue to run the opening tool along the side of the case until all five tabs have been released.
  • Continue to run the opening tool along the side of the case until all five tabs have been released.
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
  • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
  • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
  • Lift the rear panel away from the iPod.
Lift the battery up from the adhesive holding it to the iPod.
  • Lift the battery up from the adhesive holding it to the iPod.
  • Lay the battery next to the iPod (it is still connected to the logic board).
Carefully disconnect the orange ribbon cable from the hard drive.
  • Carefully disconnect the orange ribbon cable from the hard drive.
  • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
  • Lift the hard drive out of the iPod.
3 autre(s) ont terminé cette réparation.
iRobot
Membre depuis le 24/09/2009
1 Réputation
745 tutoriels rédigés
Where can I get a HDD that will fit/work in this model? 1st iPod 5GB capacity. Larger capacity would be nice but not needed.
kevin - Réponse
I'd like to know the same Kevin.
rgcastreg - Réponse
Kevin. Theydon't make hard drives for it for anymore, but they make adapters for CF card and SD cards. Of Course you can put whatever size you want in it
David Robitaille (robitaill3) - Réponse
CF adapters do not work in 1G iPods. You can find old 1.8” drives on eBay, but they must be single-platter drives. The largest I know of is 40GB.
M Smith - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 93
Total : 21,275
