Introduction
Remplacez un écran craqué ou défectueux.
Avant d'ouvrir votre iPod, assurez-vous que le bouton Arrêt est en position verrouillée. La barre orange doit être visible, indiquant que la fonction Arrêt est active.
  • Avant d'ouvrir votre iPod, assurez-vous que le bouton Arrêt est en position verrouillée. La barre orange doit être visible, indiquant que la fonction Arrêt est active.
How necessary is it to have the HOLD switch in the locked position? On my iPod the switch is stuck in the unlocked position and I can't force it into locked.
Is locking the iPod for a mechanical reason or an electrical/software reason?
gabeshaikh - Réponse
Quote from gabeshaikh:
It is for an electrical reason. If the iPod hold switch is kept on, the device will not turn on, thus ensuring the device stays powered off while performing service.
trusty - Réponse
I have a 60 GB iPod photo that needs a new Logic Board. I bought a 30 GB used iPod on eBay and replaced the Logic Board. Now the iPod thinks the hard drive is only 30 GB, when it is really 60 GB. It works, but the hard drive is not recognized for its full size. Sites like this offer a 20 GB and 40 GB logic board...I apparently need 60 GB. Can I bypass this somehow, or do I really need a logic board that is specifically made for 60 GB???
Mark - Réponse
My 30gig drive shows up as a 16.4gig. I can not for the life of me, figure out why this is doing this. Can anyone help? Thanks!
Stephan - Réponse
Hello,
First thank you for this tuto and help.
I did follow your instructions and every step was ok but when I closed my i'Pod, it kept staying on the lock position even with moving the lock button.
Now it has charged but I could not make it run.
So I did a complete reboot by connecting it to my Mac with i'Tunes to restore.
It's still locked.
What can I do?
Than You for your answer
Thomas
Voisin - Réponse
Much quicker and far easier opening from the right side instead of from the top using the blue plastic spudger. Opened in under 10sec. Do not know why this guide asks you to start from the top and work it to the left corner. Perhaps it was meant as a challenge.
Edwin Seah - Réponse
Well, I did it! I am pretty mechanically inclined, but I don't work well with small stuff. Anyway, as others mentioned, this step was the hardest for me, the included tools, worthless (to start to separate the case) As another person mentioned, I used a razor blade on the side on the upper left corner pushing down toward the metal clips, 'pop' once the first came off, then I used the blue tools to release the remaining clips. I didn't want to remove the connector in step 8, but had literally no room to work, the connector is a square push in type that is attached to the ribbon cable, I pryed with the blue tool carefully at the connector base, it popped right off! (getting is back on was more challenging, but managed with a small pair of needle nose pliers.) Had to pry the old battery out carefully - it was really in there. Got it all back together, works like a champ! Thanks ifixit!
mikesnyder - Réponse
Promptly broke both blue plastic tools. I used a putty knife to pop the case. Opening was the only hard part. I didn't disconnect the headphone cable. No problems and the battery has enough charge that I listening to Bare Naked Ladies now. Last week I installed a new hard drive in my Mac mini. IFixit is the greatest!
heldon - Réponse
If you are lucky, your battery may swell up like mind did, short of blowing up it opened the case for me. That being done really made it easy and encouraged me to do the repair myself. I still needed the proper screw driver (T6 Torx Screwdriver) to remove the two black torx screws that are found at step 10 of this repair guide. I purchased the iFixit 64bit driver kit, simply because I intend to work on several other iPods and phones, the kit is of good quality, well worth the purchase. If you have some mechanical ability, and follow the instructions, I was done in about 20 minutes, placed it back on my Bose player. I couldn't wait for it to charge, just wanted it to start playing, and after a minute or so my iPod 4th gen 20 gb was playing the music which I hadn't heard in about 3 to 4 years, as a result of a enlarged battery. As I write these comments down, I'm listening to my sweet tunes with a big smile on my mug, the sign of a satisfied customer. Thanks to iFIXIT.!!!
Alex DeLeon - Réponse
Ouvrir l'iPod peut être difficile. Ne vous découragez pas si vous devez essayer plusieurs fois avant d'y arriver. Insérez un grand outil d'ouverture pour iPod dans la jointure entre le panneau frontal en plastique et la coque arrière en métal de l'iPod, près de la prise casque. Le bord de l'outil doit pointer vers la coque arrière métallique pour éviter toute rayure accidentelle du panneau en plastique
  • Ouvrir l'iPod peut être difficile. Ne vous découragez pas si vous devez essayer plusieurs fois avant d'y arriver.
  • Insérez un grand outil d'ouverture pour iPod dans la jointure entre le panneau frontal en plastique et la coque arrière en métal de l'iPod, près de la prise casque. Le bord de l'outil doit pointer vers la coque arrière métallique pour éviter toute rayure accidentelle du panneau en plastique
  • Parcourez la jointure supérieure avec l'outil, vers le coin supérieur gauche de l'iPod. Appuyez sur l'outil dans le coin, pour créer un petit espace sur le côté de la coque.
Ajouter un commentaire
Introduisez le grand outil d'ouverture pour iPod dans le coin supérieur gauche de l'iPod, pour créer un petit espace le long de la jointure latérale.
  • Introduisez le grand outil d'ouverture pour iPod dans le coin supérieur gauche de l'iPod, pour créer un petit espace le long de la jointure latérale.
Il existe cinq onglets de retenue de chaque côté de l'iPod. Le grand outil d'ouverture pour iPod étant toujours inséré dans la jointure supérieure, introduisez un petit outil d'ouverture pour iPod dans l'espace que vous venez de créer.
  • Il existe cinq onglets de retenue de chaque côté de l'iPod.
  • Le grand outil d'ouverture pour iPod étant toujours inséré dans la jointure supérieure, introduisez un petit outil d'ouverture pour iPod dans l'espace que vous venez de créer.
  • Parcourez la jointure latérale avec l'outil d'ouverture pour iPod et ouvrez les cinq onglets.
  • Il peut s'avérer nécessaire d'appliquer des mouvements de va-e-t-vient à l'outil quand vous parcourez la jointure pour ouvrir tous les onglets.
Passez l'outil d'ouverture de l'iPod autour du coin inférieur gauche de l'iPod et le long de la jointure inférieure pour ouvrir les deux clips de retenue près du connecteur de dock.
  • Passez l'outil d'ouverture de l'iPod autour du coin inférieur gauche de l'iPod et le long de la jointure inférieure pour ouvrir les deux clips de retenue près du connecteur de dock.
Passez l'outil d'ouverture de l'iPod autour du coin inférieur droit et faites-le glisser vers le bas, le long du côté droit, pour ouvrir les cinq onglets qui maintiennent l'iPod fermé. Il suffira peut-être de faire osciller légèrement le panneau frontal de l'iPod pour ouvrir les onglets.
  • Passez l'outil d'ouverture de l'iPod autour du coin inférieur droit et faites-le glisser vers le bas, le long du côté droit, pour ouvrir les cinq onglets qui maintiennent l'iPod fermé. Il suffira peut-être de faire osciller légèrement le panneau frontal de l'iPod pour ouvrir les onglets.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
La coque de l'iPod est maintenant ouverte, mais ne séparez pas encore les deux moitiés. Une nappe orange relie toujours la prise casque à la carte mère.
  • La coque de l'iPod est maintenant ouverte, mais ne séparez pas encore les deux moitiés. Une nappe orange relie toujours la prise casque à la carte mère.
  • Ouvrez la coque comme un livre, en soulevant le bord du connecteur de dock, et posez la coque arrière à côté de la moitié avant de l'iPod.
This is the most fragile piece to work with in the whole process. Make sure you have some glasses or something and actually watch the individual pins while you reconnect the cable. I can't see so close, and didn't see what I was doing clearly. Consequently I broke the pins.
Adam Logan - Réponse
Utilisez un outil en plastique ou vos ongles pour débrancher la nappe orange de la prise casque. Assurez-vous de soulever le connecteur et non la nappe même.
  • Utilisez un outil en plastique ou vos ongles pour débrancher la nappe orange de la prise casque. Assurez-vous de soulever le connecteur et non la nappe même.
Be very careful disconnecting. In fact may want to leave connected. I "removed" the entire piece pins and all from the board and had to replace the logic board to fix. A $15 fix turned into $65. Happy to say got it fixed with a new board but this was a crucial step that cost me big time! Again leave headphone jack connected if at all possible!!
tigers27408 - Réponse
DO NOT remove the ribbon cable unless absolutely necessary. I also removed the black female plug from the logic board by mistake. However, in my case I was able to plug it back in and it still works (phew!). Lucky. I might have destroyed some soldering, I don't know ... but it works.
Paul - Réponse
At this point I damaged the motherboard irreversibly!!
This guide should be modified. You should not attempt this step. Either you replace the battery without disconnecting the ribbon. Or if you really want more room, you unscrew the other little board from the the metal half of the case.
Now I have to buy another ipod :-(
Guillaume Barreau - Réponse
It is worth noting that the connector for the iPod 4th gen and the iPod photo/color are NOT compatible. The 4th gen has only 10 pins, whereas the photo/color have 12 pins.
Miles Raymond - Réponse
I successfully installed the new battery without removing the ribbon cable.
Michael Caputi - Réponse
&&^&. Just ripped the circuit. Destroyed my iPod. Thanks for nothing. Other fixes do not have this step. Horribly disappointed. This needs to be deleted!
Adam - Réponse
Any idea if it can be resoldered?
Adam - Réponse
Saisissez le disque dur d'une main et débranchez soigneusement la nappe orange du disque dur de l'autre.
  • Saisissez le disque dur d'une main et débranchez soigneusement la nappe orange du disque dur de l'autre.
  • Si la nappe ne sort pas facilement, il peut être judicieux de déplacer délicatement la nappe d'un côté vers l'autre.
Note carefully how the orange ribbon cable is connected, as there are more holes than pins (at least on my hard drive) which makes it a little tricky to put it back correctly. Not that difficult, but I had to do it twice...
osset - Réponse
Just a curious question, since the hard drive is quite fragile, can it be replaced with a lets say: 8 GB fast CF card with built-in ATA?
callmered - Réponse
It can with an adapter. I picked one up on ebay for $2 from Hong Kong.
Eric Rumsey -
The Hard Drive can be replaced with a CompactFlash to Toshiba 1.8-inch IDE Hard Drive Converter and a CF Card. It works! http://www.dx.com/p/cf-to-toshiba-1-8-in...
Lion - Réponse
Décollez la bande adhésive noire recouvrant la nappe du disque dur.
  • Décollez la bande adhésive noire recouvrant la nappe du disque dur.
Utilisez la pointe de votre doigt ou un spudgher pour faire soigneusement pivoter le connecteur noir fixant la nappe du disque dur à la carte mère. Notez que le clip noir de retenue s'ouvre de 90 degrés vers le haut, dans le sens de la nappe.
  • Utilisez la pointe de votre doigt ou un spudgher pour faire soigneusement pivoter le connecteur noir fixant la nappe du disque dur à la carte mère. Notez que le clip noir de retenue s'ouvre de 90 degrés vers le haut, dans le sens de la nappe.
Hi. My ipod doesn't have a clip retaining the ribbon. How is mine held in place? I can't see how it would have been held in place. Your help is required.
Spencer - Réponse
Is the connection on the board ZIF?
krypta420 - Réponse
Yes. The ribbon cable may also be covered with a small sheet of thin black tape.
E West -
Tirez la nappe orange du disque dur tout droit hors de son connecteur.
  • Tirez la nappe orange du disque dur tout droit hors de son connecteur.
Déconnectez soigneusement de la carte mère le connecteur blanc de la batterie. Assurez-vous de ne tirer que sur le connecteur même et non sur les câbles.
  • Déconnectez soigneusement de la carte mère le connecteur blanc de la batterie. Assurez-vous de ne tirer que sur le connecteur même et non sur les câbles.
Use of a small plastic separation tool to lift on the shoulders of the connector will make this easier. The body of the connector occupies most of the vertical portion of the assembly.
The wires are connected to the flat shoulder piece.
jimjarvis - Réponse
Utilisez un spudger pour faire basculer les barres noires de fixation retenant les connecteurs de l'écran et de la molette cliquable sur la carte mère.
  • Utilisez un spudger pour faire basculer les barres noires de fixation retenant les connecteurs de l'écran et de la molette cliquable sur la carte mère.
  • Si vous avez un iPod Photo, le connecteur d'écran (à droite de l'image) est plus proche du centre de la carte mère.
This photo shows the display connector of an iPod 4th gen. The display connector of the photo/color is quite different.
Retirez les 6 vis Torx T6 noires fixant la carte mère sur le panneau frontal.
  • Retirez les 6 vis Torx T6 noires fixant la carte mère sur le panneau frontal.
  • Si vous avez un iPod Photo, il n'y aura que 5 vis, car il n'y a pas de vis dans le coin supérieur droit de l'iPod.
Faites glisser la nappe orange de la molette cliquable hors sur son connecteur. Vous devez déverrouiller ce connecteur avant de faire glisser la nappe. Le mécanisme de verrouillage se trouve sur le côté opposé de l'endroit où la nappe est insérée et pivote de 90 degrés vers le haut. Utilisez un spudger pour soulever le mécanisme de verrouillage.
  • Faites glisser la nappe orange de la molette cliquable hors sur son connecteur. Vous devez déverrouiller ce connecteur avant de faire glisser la nappe. Le mécanisme de verrouillage se trouve sur le côté opposé de l'endroit où la nappe est insérée et pivote de 90 degrés vers le haut. Utilisez un spudger pour soulever le mécanisme de verrouillage.
Soulevez soigneusement la grande extrémité de la carte mère et débranchez le connecteur de l'écran.
  • Soulevez soigneusement la grande extrémité de la carte mère et débranchez le connecteur de l'écran.
  • Soulevez la carte mère hors de l'iPod.
Soulevez le panneau de l'écran hors de l'iPod. Il se peut qu'un adhésif pas très fort relie l'écran au panneau frontal.
  • Soulevez le panneau de l'écran hors de l'iPod. Il se peut qu'un adhésif pas très fort relie l'écran au panneau frontal.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
38 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
iRobot
Membre depuis le 24/09/2009
1 Réputation
750 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 84
Total : 30,216
