Introduction
Battery not lasting long? Swap it out (requires soldering).
Insert the large iPod opening tool into the seam between the front case and rear panel of the iPod, below the dock connector. Run the tool back and forth to create an opening. The tool's edge should point toward the rear panel to prevent any accidental scratching of the aluminum front case.
Insert a small iPod opening tool into the seam on the Hold button side of the iPod, with the edge of the tool pointing toward the rear panel.
Gently enlarge the existing gap by pressing/wiggling the small iPod opening tool into the gap near each of the two tabs attached to the rear case, pushing the clips toward the center of the iPod until both have been freed.
Repeat the same procedure listed in the previous step to free the five clips along the headphone jack side of the iPod.
After ensuring all tabs are free, separate the two halves of the iPod.
The rear panel is now free from the iPod.
Remove the following 3 screws:
Two 3 mm Phillips screws near the dock connector.
One 4 mm Phillips screw along the edge of the logic board.
Note that the 4mm screw has slightly wider pitch; you'll need this when putting the unit back together.
Peel up the ground strap connecting the battery to the logic board.
Insert the flat end of a spudger between the battery and the headphone jack side of the front case to pry the battery up off the adhesive securing it to the front case.
Rotate the battery out of the iPod and lay it next to the iPod. The battery is still soldered to the logic board by three wires, so don't remove it entirely.
Gently lift up on the dock connector end of the logic board to ensure the logic board is free.
Grasp the end of the logic board near the battery connector with one hand, and hold onto the rest of the iPod with your other hand.
Slide the logic board out of its holding brackets on the rear of the display.
During the disassembly of the board I somehow "delaminated" the display. The result was that the display (after the battery was changed and the device closed again) looked "cloudy". From some angle you couldn't see anything at all anymore. The solution was to heat up the hole device with a hair dryer and rest it on it's front side for about an hour. After that it looked absolutely perfect again. I am not sure whether the heating is really necessary (maybe just lying the ipod on the front side over night would have the same effect) and surely one should be careful to not overheat the device.
Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
Both ribbon cables were especially difficult to put back in. I can't say I succeeded in getting the nano to work again. If you can avoid detaching the cables, do it. If you're replacing the clickwheel, there's no way of avoiding it unfortunately.
A little tip if you are replacing the screen: Reconnect this ribbon cable from the new screen BEFORE affixing the screen to the adhesive! It will make it much easier. Also be sure that the little black things are UP before trying to put the ribbon in, and make sure you put them DOWN before closing up! The black things on the receptacle "lock" the cable in place, so it is important that you have it STRAIGHT or it wont work. Good luck!
Use a spudger to slide the display ribbon out of its connector.
Getting the display ribbon back in place is the most difficult maneuver in the whole fix. I actually broke the black plastic tab in half while trying to close it back down, (be very gentle with it!). Managed to put the broken half back in(tweezers and patience) and get that ribbon in and put it back down. This battery replacement was the most difficult/tedious repair I have ever done. Don't do it unless you are brave and stubborn.
You can leave out this steps with disconnecting the two cables.
Without disconnecting the two cables, one can separate the two pieces only 1/2 inch. This is enough to work carefully with the soldering iron and change the battery.
It's a little bit difficult to work with the needle to open the three holes after removing the old battery - but you can do it.
From the reading of the other notes it seems to me easier than to disconnect the two cables
Use a spudger to flip up the black plastic tab holding the orange click wheel ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
Use a spudger to slide the click wheel ribbon out of its connector.
Don't do this unless you have to. Getting this ribbon back in is nearly impossible.
Quote from daisystanton:
Try using tweezers or medical clamps to reach in that tight spot. Use these tools to also connect the click wheel ribbon back to the logic board.
Stamp tweezers worked great for the ribbon cable! (Search eBay or Amazon, or your local hobby store.) This would be a useful tool for iFixIt to add to their inventory.
The logic board and battery are now free from the iPod.
Peel the orange kapton tape covering the battery leads.
Begin by heating the exposed end of the white battery lead with the tip of a soldering iron while simultaneously pulling the lead away from the connection, using tweezers to grasp the lead by the insulation.
De-solder the remaining leads, following the procedure illustrated above.
If present, remove the small piece of shrink tube protecting the new battery's positive lead.
To open the solder holes, open a safety pin and push it against the solder blocking the hole. At the same time, heat the same solder pad from the other side of the logic board. Opening the holes completely will require repeating this procedure several times from alternating sides of the logic board.
A desoldering pump is helpful and makes this step much easier. You basically heat the solder up til it goes liquid, then hit the button on the desoldering pump and all the solder is taken off leaving the hole totally clean.
Place the logic board flat on a table with the gold ground contacts (shown in orange) facing up.
Using a pair of tweezers, insert the stripped ends of the battery leads into their respective holes.
Insert the black lead into the hole nearest the hold switch (shown in red).
Insert the red lead into the center hole.
Insert the white lead into the hole furthest from the hold switch.
Flip the logic board and battery over so the bare ends of the battery leads are facing up.
Solder the connection by momentarily placing the tip of the soldering iron against the connection, melting solder into the connection, and quickly removing both the solder and the tip of the soldering iron from the connection. The solder should flow around the new battery lead, solidly connecting it to the pad on the logic board.
Solder the other two battery leads in the same fashion, taking care not to bridge any of the connections together.
Rotate the battery toward the logic board and place it flat in its void, bending the cables as necessary.
Annulation : je n'ai pas terminé ce guide.
84 autre(s) ont terminé cette réparation.
4 commentaires
I skipped steps 8,9,11-17, and 21.
Step 19> when un-soldering the old battery wires, make sure to leave solder on the pads and in the holes.
I replaced steps 22-24 with Step 22-24> Very carefully and precisely:
-Place the black lead onto the pad nearest the hold switch (shown in red) with the end of wire pointing away from the battery.
-Place the red lead onto the center pad with the end of wire pointing away from the battery.
-Place the white lead onto the pad furthest from the hold switch with the end of wire pointing away from the battery.
Gently hold each wire in place on the pad while applying the soldering iron taking care not to touch the wire to any other pad or trace (note black wire). When the wire sinks into the solder, remove heat. Hold wire until solder has set.
Do step 25 and charge battery. Much simpler and less risk.
For all newbies, make sure that your soldering spots are neat and clean. Your workplace must be clean! Too hasty repair...and you'll reassemble your Pod once again.
Thanks for the neat repair guide! Much appreciated!" Now I can enjoy my "new Pod" for another 8years at least! No that's what I call environmental awareness! (built in 2005)
Success! The instructions were clear and helpful. This was the third battery for my iPod, so the desoldering step took a fair amount of time. I am not very experienced with soldering, so I practiced on a little blinking christmas tree kit before attempting this, and I think that was useful.
Turn on the notes and READ thru all the steps and the notes, especially the ones involving the ribbon cables.
patjmccarthy - Réponse
