Aller au contenu principal
iRobot Roomba 4160 Battery Replacement
  1. iRobot Roomba 4160 Battery Replacement, Battery: étape 1, image 1 de 1
    • Make sure the Roomba is turned off to avoid an electric shock.
    • Turn the Roomba upside down, and place it so that the underside is exposed. The wheels and brushes should be visible.
    • Do not attempt to open up the yellow battery pack. You may get shocked or burned by the battery acid.
  2. iRobot Roomba 4160 Battery Replacement: étape 2, image 1 de 2 iRobot Roomba 4160 Battery Replacement: étape 2, image 2 de 2
    • Identify the yellow plastic rectangular battery, directly to the right of the spinning brush.
    • Place your index fingers on the small rectangular plastic tabs on both sides of the battery. Push the tabs in until the battery comes loose.
    • Pull battery out using your fingers.
To re-install battery, follow these instructions in reverse order.
Garrett Rasmussen
Membre depuis le 04/07/14
225 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 6-4, Forte Spring 2014 Membre de l'équipe Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 940
