Aller au contenu principal
iRobot Roomba 551 Brush Case Replacement
Ce dont vous avez besoin
  1. iRobot Roomba 551 Brush Case Replacement, Side Brush: étape 1, image 1 de 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Brush Case Replacement: étape 2, image 1 de 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Brush Case Replacement: étape 3, image 1 de 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Brush Case Replacement, Bottom Plate: étape 4, image 1 de 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Brush Case Replacement: étape 5, image 1 de 2 iRobot Roomba 551 Brush Case Replacement: étape 5, image 2 de 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Brush Case Replacement: étape 6, image 1 de 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Brush Case Replacement, iRobot Roomba 551 Dirt Bin Replacement: étape 7, image 1 de 1
    • Push on the dirt bin release button, and pull gently.
  8. iRobot Roomba 551 Brush Case Replacement, Brush Case: étape 8, image 1 de 1
    • Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
  9. iRobot Roomba 551 Brush Case Replacement: étape 9, image 1 de 1
    • Grab the brush case and pull upwards to remove.
John McTigue
Membre depuis le 01/31/14
331 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 13-14, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 membres
19 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 11
Total : 762
