Aller au contenu principal
iRobot Roomba 551 Brushes Replacement
Ce dont vous avez besoin
  1. iRobot Roomba 551 Brushes Replacement, Side Brush: étape 1, image 1 de 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Brushes Replacement: étape 2, image 1 de 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Brushes Replacement: étape 3, image 1 de 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Brushes Replacement, Bottom Plate: étape 4, image 1 de 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Brushes Replacement: étape 5, image 1 de 2 iRobot Roomba 551 Brushes Replacement: étape 5, image 2 de 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Brushes Replacement: étape 6, image 1 de 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Brushes Replacement, Brushes: étape 7, image 1 de 2 iRobot Roomba 551 Brushes Replacement, Brushes: étape 7, image 2 de 2
    • Pinch the yellow tabs on the sides of the brush cage and lift up to open.
  8. iRobot Roomba 551 Brushes Replacement: étape 8, image 1 de 3 iRobot Roomba 551 Brushes Replacement: étape 8, image 2 de 3 iRobot Roomba 551 Brushes Replacement: étape 8, image 3 de 3
    • Grab each brush and lift upwards to remove.
John McTigue
Membre depuis le 01/31/14
331 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 13-14, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 membres
19 tutoriels rédigés
2 commentaires
Should be no need to remove the back plate. Just open the brush cage and lift out the brushes
Gunnar Nybraten - Réponse
I did all that, bought a new brush cage and it is still announcing error 2-clean brushes.
Christa Eads - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 104
30 derniers jours : 449
Total : 6,209
