Introduction
This guide explains how to remove the side brush motor from your Roomba.
Pièces
Aucune pièce nécessaire.
Place your Roomba upside-down on a hard surface.
  • Place your Roomba upside-down on a hard surface.
If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
David Forrest - Réponse
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Ajouter un commentaire
Gently pull upwards on the brush to remove it.
  • Gently pull upwards on the brush to remove it.
Rotate the Roomba upside-down so the bottom is facing towards you.
  • Rotate the Roomba upside-down so the bottom is facing towards you.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Carefully lift the bottom plate.
  • Carefully lift the bottom plate.
  • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly. Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly. Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly.
  • Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly.
Gently pull on motor assembly to remove.
  • Gently pull on motor assembly to remove.
Aaron Jacobs
Membre depuis le 31/01/2014
525 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 13-14, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 membres
13 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 7
Total : 643
