Introduction
This guide is in case the battery for the iRobot Roomba 980 has failed to work or is performing poorly. It may be defective, damaged during use or reached the end of its charging life-cycle. Replacing the battery is a quick and easy process that will not take much time away from your daily routine.
Ce dont vous avez besoin
Flip over the device and remove the two 11.5 mm screws using the Phillips #1 screwdriver.
3 autres ont terminé cette réparation.
