Introduction
This guide will teach someone how to access and remove the screen display of their iRulu AX760. In following this guide you will learn how disconnect and replace the screen display.
Use a plastic opening tool or metal spudger to free the rear cover. Insert your spudger into the side of your tablet. Crack open each edge and remove the cover.
  • Use a plastic opening tool or metal spudger to free the rear cover.
  • Insert your spudger into the side of your tablet.
  • Crack open each edge and remove the cover.
Ajouter un commentaire
Open your tablet.
  • Open your tablet.
Take your plastic flat head tool and insert it under the battery.
  • Take your plastic flat head tool and insert it under the battery.
  • Lift the battery up.
  • Make sure to remove any tape from the battery.
Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard. Keep the wires of the battery taught.
  • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
  • Keep the wires of the battery taught.
  • The iron should only be pressed to the solder for 2-3 seconds max.
  • Be very carful, the soldering iron will be very hot!
  • Visit this link for information about soldering. Comment souder et dessouder des connexions
Remove your old battery and replace it with the new battery.
  • Remove your old battery and replace it with the new battery.
Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets. Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
  • Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Pull the digitizer ribbon cables straight out of their sockets.
  • Pull the digitizer ribbon cables straight out of their sockets.
Pull the camera out of the device.
  • Pull the camera out of the device.
There are two thin adhesive strips under the battery that run vertically along the left and right side. Carefully wedge a plastic card or spudger under the battery and along both adhesive strips. Gently work the card or spudger up and down to free the battery.
  • There are two thin adhesive strips under the battery that run vertically along the left and right side.
  • Carefully wedge a plastic card or spudger under the battery and along both adhesive strips. Gently work the card or spudger up and down to free the battery.
    • Do not use metal tools, and do not bend or puncture the battery.
WARNING: SOLDERING IRONS BECOME EXTREMELY HOT.  DO NOT TOUCH For information on soldering and desoldering, check this link. You must desolder several sets of contacts before attempting to remove the motherboard.
  • WARNING: SOLDERING IRONS BECOME EXTREMELY HOT. DO NOT TOUCH
  • For information on soldering and desoldering, check this link.
  • You must desolder several sets of contacts before attempting to remove the motherboard.
  • You must desolder the BAT (battery), LED, SPK (speaker), and ANT (antenna) contacts.
Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver
  • Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver
Use a plastic spudger to push the tab, releasing the motherboard from the screen. You can now remove the old motherboard. You will not need a metal spudger in order to re-place the motherboard
  • Use a plastic spudger to push the tab, releasing the motherboard from the screen. You can now remove the old motherboard.
  • You will not need a metal spudger in order to re-place the motherboard
Remove the plastic peel attached to the back of the screen display.
  • Remove the plastic peel attached to the back of the screen display.
Remove the grey wire from the back of the screen display. Remove the grey wire from the back of the screen display.
  • Remove the grey wire from the back of the screen display.
Insert the plastic spudger underneath the screen display and lift.
  • Insert the plastic spudger underneath the screen display and lift.
Continue lifting the screen by hand and pull it out until it is completely removed. Continue lifting the screen by hand and pull it out until it is completely removed.
  • Continue lifting the screen by hand and pull it out until it is completely removed.
Jamison Kritz
Membre depuis le 20/03/2018
205 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S6-G4, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 29
