Introduction
The speaker is located inside the phone underneath the front cover. A T6 screwdriver is needed to access the speaker.
Pièces
Aucune pièce nécessaire.
Press down the button on the back panel.
  • Press down the button on the back panel.
Ajouter un commentaire
Push the back cover upwards. Push the back cover upwards.
  • Push the back cover upwards.
Remove the back cover from the phone. Remove the back cover from the phone.
  • Remove the back cover from the phone.
Press the silver button on the top of the phone.
  • Press the silver button on the top of the phone.
Pull the top of the case apart.
  • Pull the top of the case apart.
  • Slide thumbnail down the case seam to separate the rest of the case.
Gently pull the case apart.
  • Gently pull the case apart.
  • Careful! Do not to bend the plastic tabs.
Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture. Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
  • Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
Remove the panel that covers the motherboard. If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
  • Remove the panel that covers the motherboard.
  • If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
Remove the LCD screen frame.
  • Remove the LCD screen frame.
Remove the motherboard.
  • Remove the motherboard.
Locate the speaker on the back of the removed panel.
  • Locate the speaker on the back of the removed panel.
Use nails to gently lift the speaker up; speaker may be slightly glued to the panel.
  • Use nails to gently lift the speaker up; speaker may be slightly glued to the panel.
When the speaker is loose, gently lift the speaker out of the panel.
  • When the speaker is loose, gently lift the speaker out of the panel.
Job Jao
Membre depuis le 08/10/2010
37 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-27, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 3-27, Regan Fall 2010
CPSU-REGAN-F10S3G27
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 2,498
