Introduction
The guide takes place from the Camera Lens Assembly guide.
Pièces
Aucune pièce nécessaire.
Locate the memory card and battery card latch on the bottom of the camera.
  • Locate the memory card and battery card latch on the bottom of the camera.
  • Slide the latch to the open position.
Ajouter un commentaire
Open the battery latch, and slide the battery release lever to the right.
  • Open the battery latch, and slide the battery release lever to the right.
Remove the battery from the camera.
  • Remove the battery from the camera.
Using a size #00 Phillips screwdriver, remove the three 4.58 mm screws on the bottom of the camera.
  • Using a size #00 Phillips screwdriver, remove the three 4.58 mm screws on the bottom of the camera.
  • Use this screwdriver for all screws in the device.
Remove the 3.15 mm screw on the left side of the camera.
  • Remove the 3.15 mm screw on the left side of the camera.
Remove the left side casing. Remove the left side casing.
  • Remove the left side casing.
Remove the two 3.15 mm screws on the right side of the camera.
  • Remove the two 3.15 mm screws on the right side of the camera.
Remove the bottom right panel.
  • Remove the bottom right panel.
Gently remove the back casing. Start at the bottom and carefully pry towards the top to get this piece free.
  • Gently remove the back casing.
  • Start at the bottom and carefully pry towards the top to get this piece free.
Remove the two black 5.35 mm screws that hold in the front faceplate. There may be a third screw the the right of the lens assembly.
  • Remove the two black 5.35 mm screws that hold in the front faceplate.
  • There may be a third screw the the right of the lens assembly.
Carefully remove the upper assembly, which houses the buttons and the flash battery. Carefully remove the upper assembly, which houses the buttons and the flash battery. Carefully remove the upper assembly, which houses the buttons and the flash battery.
  • Carefully remove the upper assembly, which houses the buttons and the flash battery.
Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
  • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
Remove the three black 5mm screws attached to the lens frame. Remove the three black 5mm screws attached to the lens frame.
  • Remove the three black 5mm screws attached to the lens frame.
Remove the lens frame.
  • Remove the lens frame.
Lift out the circuit board as shown.
  • Lift out the circuit board as shown.
Lift the two black latches that hold the connector ribbons in place. Disconnect the two ribbons.
  • Lift the two black latches that hold the connector ribbons in place.
  • Disconnect the two ribbons.
Remove the lens assembly as shown.
  • Remove the lens assembly as shown.
Remove four 4mm screws from the lens assembly.
  • Remove four 4mm screws from the lens assembly.
Carefully turn over the assembly. Carefully turn over the assembly.
  • Carefully turn over the assembly.
Remove the Fixed Frame Unit by separating it from the assembly. Remove the Direct Frame Unit from the assembly.
  • Remove the Fixed Frame Unit by separating it from the assembly.
  • Remove the Direct Frame Unit from the assembly.
Remove the 1st lens frame from the lens assembly.
  • Remove the 1st lens frame from the lens assembly.
Detach the 2nd Frame Unit from the assembly.
  • Detach the 2nd Frame Unit from the assembly.
Remove the 4mm screw from the lens housing.
  • Remove the 4mm screw from the lens housing.
Separate the lens housing.
  • Separate the lens housing.
  • Replace the lens by gently prying away from the assembly.
4 autre(s) ont terminé cette réparation.
Caleb Fink
Membre depuis le 11/10/2010
186 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 9-22, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 17
Total : 11,841
