Aller au contenu principal
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 questions Voir tout
Question close
How do I change the front parking light bulbs?
Both front parking lights are blown. I can't change them without removing the parking light assemblies. Under the hood there is a white tab on each one with a small phillips screw. I removed those but the assemblies still won't come out. What are my next steps ?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Mark, follow this:"
1 Open the hood on your Toyota Camry and locate the parking lights. They are on the outside of the headlights toward the front fender.
2 Remove the clip, if your year Camry has one, that protects the bulb ballast. Pull up on the clip to remove it.
3 Remove the electrical plug running to the bulb ballast. Squeeze the release tab on the electrical connector and pull the plug off.
4 Turn the bulb counterclockwise to unlock it and pull it out of the housing.
5 Install a new bulb. Installation is the reverse of removal." from here. There are more directions on here as well. Hope this helps, good luck.
Indice 1
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,396
