Aller au contenu principal
Model A1318 / 32 or 64 GB capacity
299 questions Voir tout
Question close
Digitizer is unresponsive after being submerged in water.
I dropped my ipod touch 32gb 3rd gen in the water. I bought replacement parts for it (lcd/digitizer), the new LCD works fine, but the digitizer isn't responding. How do I replace the wire port or fix this so I can use it again? Any help is appreciated!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
You may want to start by removing the existing glasss and digitizer assembly first, inspect the connectors thoroughly as well as the connectors on the ipod logicboard. if possible, use a clean and dry tooth brush to first brushing it dry. If it still looks dirty, then clean it with isobutyl alchol. Then brush the surfact one more time, making sure that the connector surface is very nice and shiny. Wait for it to dry thoroughly before reconnecting because alchol does have a large water content.
Reconnect and try it again. if that does not work, then buy a replacement digitizer plus glass from ebay and install that one in. That should elimnate any posibility that the logic board digitier control module may be defective.
Do check iFixit for instructions on how to remove your existing digitizer. If is fairly straight forward.
Indice 0
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 595
