Mikuni Carburetor supplying too much gas to start engine?
I'm working on an old Generac G2600 generator (model 8836-0) with a Kawasaki FA210D-AM80 engine with a "float-type" mikuni carburetor.
Compression is good. Spark is good w/ new plug.
The engine starts with a shot of starter fluid. It also starts if I pull the gas line and have little gas in the carb.
Once it starts, it runs okay until it runs out of fuel.
If I leave the gas supply connected however, is seems to be way too rich, and the engine won't fire.
I've adjusted the float, replaced the float value and checked that it does indeed stop the gas flow.
All of the jets and passages appear to be clear.
Any suggestions would be welcome.
Thanks
gpowers, would you have a model number for your generator? If I understand you correctly, when it runs it runs. But it is hard to start and floods your plugs?
par oldturkey03
It's a Generac model G2600 with a Kawasaki FA210D engine.
It was also sold as a Craftsman model # 580.328330.
And yes. When it runs, it runs strong until it runs out of gas.
The only suggestion from the service manual is the float adjustment, but it has been adjusted and the float valve was replaced.
Thanks.
par gpowers
