Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
2.26 or 2.4 GHz / White plastic unibody enclosure
Questions au sujet de 763 Voir tout
Question close
Will replacement trackpad solve my problem?
I own a MacBook A1342. Like many others before me I have problems with the trackpad.
The problem is that I cannot use the mechanical click function. I've tried fiddling with the trackpad screw under the battery but with no luck. Also, I've played around with settings, reset the PRAM etc.
I used to be perfectly happy with my MacBook so I am about to go out and buy a new trackpad to replace the old one. As they are expensive I want to make sure that this is a solution to my problem. Might there be other malfunctioning hard- or software issues I haven't checked? Can it be the logic board?
Thank you for your time!
Répondre à cette question J'ai le même problème
Indice 0
Commentaires:
I have the same problem , but neither tap-to-click or mechanical click are working... Anybody has being throug the same problem??
Thanks in advance
par
Ajouter un commentaire
1 solution
Probably not the logic board if it was once working fine and there haven't been any spills or anything. Does your tap-to-click function work fine? If so, then it's likely the trackpad. You can try to remove it (remove bottom plate, battery, then the 4 tiny screws holding the metal bands over the trackpad), clean around the edges and then re-install it. Spend the time adjusting the leveling screw to the correct depth and then try the click action again. If it still doesn't work, you might need to replace the trackpad.
Cette réponse a-t-elle été utile ?
Indice 0
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 936
