Aller au contenu principal
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 questions Voir tout
How do I replace wheel bearings in my 2004 pontiac grand am
How do I replace wheel bnearings in my 2004 Pontiac Grand-Am
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
cspearcy. for the front wheel bearing :"
WHEEL BEARING/HUB REPLACEMENT - FRONT
Removal Procedure
1. Raise the vehicle. Refer to LIFTING AND JACKING THE VEHICLE in General Information.
2. Remove the tire and wheel assembly. Refer to TIRE AND WHEEL REMOVAL AND INSTALLATION in Tires and Wheels.
3. Remove the wheel drive shaft nut. Refer to AXLE SHAFT .
4. Remove the brake rotor. Refer to BRAKE ROTORS .
5. Disconnect the ABS sensor harness connector from the retaining bracket and wiring harness.
6. Remove the hub and bearing assembly bolts.
7. Remove the hub and bearing assembly from the steering knuckle.
And if you are more of a visual learner, check this video. Hope this helps, good luck.
Indice 0
Ajouter une réponse
cspearcy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 9
Total : 6,929
