How to connect a RC Charger to iPhone 4 batteries?
Hello guys,
I am attempting to built a charging/disscharging/testing system for iPhone batteries. Because I have a lot of aged and water damaged ones...
Should this setup work?
The RC Charger confirms that it is a single cell with 3,7V. But after 20 seconds it says the battery is full.
Did I wire it correctly? Can someone confirm?
Thanks for your time! :)
1 commentaire
does that charger measure volts or amps? in simple terms, Amps will tell if it is "good", volts will tell charge.
par micahchetrit
