Aller au contenu principal
Modèle A1238 / avec disque dure de 80, 120 ou 160 Go / façade en métal noir ou argenté
Questions au sujet de 955 Voir tout
iPod always shows charging please wait!
When I plug it into a wall charger it will play the music but as soon as you unplug it it goes to dead and if you plug it into a the computer it says charging please wait. I restored it and the computer and I tunes fails to reconize it. Plugging it into the was it now say plug in to i tunes to restore but it wont when I do. I was told by a repair shop that it was the hard drive, but I think it might be the battery! Any suggestions!
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
Fix Kits pour batterie de MacBook
À partir de $69.99
Buy Now
À partir de $69.99
Buy Now
1 réponse
Solution retenue
Kenny, first I would replace the battery. Here is the guide for that, also, check the dock connector. Make sure there is no corrosion and or bend or broken pins. It is also possible that it is the PMIC and the least likely culprit would be the hard drive. Start with one repair at a time, change the battery first. Hope this helps, good luck.
Cette réponse est utile ?
Score 1
Ajoutez une réponse
Kenny sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 11
30 derniers jours : 37
Total : 1,828
