Aller au contenu principal
La PlayStation 3 (ou communément appelé la PS3) est le troisième système de divertissement informatique à domicile produit par Sony Computer Entertainment, et le successeur de la PlayStation 2. Il a été commercialisé le 11 Novembre 2006.
Questions au sujet de 700 Voir tout
Ps3 won't work on hdmi cable. No signal
My ps3 won't work!
It has a hdmi cable but no signal!!
I tried different ports and different cables
But no luck. I also tried holding it down to reset the video settings but still no luck!!
PLEASE HELP I JUST BOUGHT IT LAST WEEK
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Commentaires:
you say diffirent cables, you mean hdmi or also scart?
par
it won't work
par
I have no on or off switch on the back of the ps3
par
try using the compant cablde for the ps3 #the ps2 video cable
and then go to settings - video setting than click the first one than go to the top of the line you should see hdmi and than click x than x again than switch to hdmi
par
Hi I have a PS3 and the HDMI port and AV port both of them do not work they glitch out when I try to plug any of them in and they have like lines and red and green square glitchy things in it what does that mean
par
Ajouter un commentaire
2 solutions
Solution retenue
1 make sure tv or monitor is on and change source to proper input IE Hdmi 1 or 2 etc.
2 Ensure your ps3 is off but ready to be turned on. Fat ps3 has switch in back that need to be in on position.
3 hold power button for 5 to 6 seconds and let go after 2nd beep, it should come on with a beep and wait for 2nd beep.
4 this should reset your video, if display flickers then it should come up.
5 if it doesn't, try turning the power off then on again. Repeat steps 2 to 4 if it doesn't work.
If you keep trying and it doesn't work, then your unit might have to be repaired.
Cette réponse a-t-elle été utile ?
Indice 3
Commentaires:
Mine does this no video at all
par
Worked great ty I was freaking out for a second..lol
par
Awesome! Thanks
par
What part would need to be replaced?
par
Tried it today and it worked like a charm the first time! Thank you!
par
hey guys im jesse
mine wasnt coming on at all and i decided to get an av cable which worked fine but fifa 18 graphics sucks on it
so i decided to go buy a hdmi to av converter but still the same $@$* smh
Indice 0
Ajouter une réponse
Jesse sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 121
30 derniers jours : 469
Total : 46,991
