You can restore it. What you need to do is put phone in DFU mode. To achieve DFU mode, turn off your phone, plug it into your computer and follow these steps.
Once the phone is off and plugged in....
1) Push and hold iPhone power button for 3 seconds.
2) Then press and hold the home button for 10 seconds while still holding the power button.
3) Release the power button but continue to hold down the home button.
4. iTunes should say something about the phone being in recovery mode and needs to restore so go ahead and restore.
If this works then problem solved. If not, look up DFU mode on google and if you still cannot get it to restore reply to this.
As for the power flex cable, what exactly are you talking about? You may have broken something but I can't tell by the description
Good Luck! I'll check on this later today.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
